Old 01-19-2011, 11:40 PM   #1
Webwillie
Webwillie's Avatar
blazer gas filler spout grommet install
Has anyone got any suggestions/pics for installing new rubber grommet around gas filler spout on 72 blazer. I've been playing around with mine and it sure seems tight. Should I install grommet in body first and then try and push filler spout thru?
Thanks for the suggestions.
Webwillie is offline   Reply With Quote
Old 01-20-2011, 10:42 PM   #2
blazintowers
blazintowers's Avatar
Re: blazer gas filler spout grommet install
been awhile since doing mine but liquid dish soap always helps with grommets and i think i did pull the filler at the same time to replace the rest of the rubber hoses to the tank.
blazintowers is offline   Reply With Quote
Old 01-29-2011, 06:58 PM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I 2nd the dish soap.
Worked great when I did mine.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 01-29-2011, 07:40 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Dish soap and then use a small screw driver if needed to press the inside of the grommet into place.....
.....however if you scratch your paint don't blame me
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-29-2011, 08:32 PM   #5
Team
just did mine yesterday, used dish soap to put grommet in without the filler tube in place, then used some 2" long screws through the round mounting plate on this inside to draw the filler neck through the grommet (then replace with proper screws of course), my wife kept pressure on the grommet from the outside just in case it tried to pop out, worked great
Team is offline   Reply With Quote
Old 01-29-2011, 11:04 PM   #6
BobbyK
BobbyK's Avatar
"Gromet"
So that's what the wife calls it eh?
Old 01-30-2011, 08:23 AM   #7
Team
bobbyk, your pretty funny, after reading the post again the imagery is unmistakeable,
