Old 03-12-2003, 11:42 AM   #1
dubie
dubie's Avatar
Cam shaft ID
Well my 350 block is off to the machine shop this morning. After removing the pistons and the cam shaft I came to the conclusion that this engine has been apart once before. The camshaft is in excellent shape and doesn't appear to be a factory one. Is there some place I can look for an ID on it?? I took a quick look at it and only found a single digit # stamped into the end so far.
1 more question..... are the bottoms of the piston rods stamped with the cylinder # from the factory?
Thanks everyone
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-12-2003, 12:33 PM   #2
jhow66
jhow66's Avatar
Not on bottom but sometimes on each halve at parting line.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 03-12-2003, 01:23 PM   #3
dubie
dubie's Avatar
Ok i found some numbers. It has GM9 and then below it, it looks like 6930. Anyone know where I can find out what this is?
Old 03-12-2003, 01:35 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Tim, thats the same cam I just removed my truck. It's a stock small block cam from GM. It has .410 lift on the exhaust. Go to www.nastyz28.com
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-12-2003, 01:39 PM   #5
70c10
67-72 Addict!
70c10's Avatar
389(6930) Hydraulic Lifter Cam...
Came in such engines as the 283, 307 and 327.
.390 Intake, .410 exhaust
310 intake duration
320 exhaust duration
1.50 rocker ratio
Jim
Old 03-12-2003, 01:54 PM   #6
dubie
dubie's Avatar
Thanks a bunch Jim
Old 03-12-2003, 02:02 PM   #7
70c10
67-72 Addict!
70c10's Avatar
No problem Tim, congrats on the new motor!
Jim
Old 03-12-2003, 02:41 PM   #8
dubie
dubie's Avatar
Thanks!! Everything should be back from the machine shop in 1 week, so after I get it back, i am gonna paint it and post some pics after it's all back together
Old 03-12-2003, 03:06 PM   #9
70c10
67-72 Addict!
70c10's Avatar
What color scheme did you decide on?
Jim
Old 03-12-2003, 03:14 PM   #10
dubie
dubie's Avatar
ORANGE!!!! The engine will be done in Chevy orange, gloss black and CHROME!! The cab and front clip will be orange with a black flatbed.
Old 03-12-2003, 03:21 PM   #11
70c10
67-72 Addict!
70c10's Avatar
Sounds cool!, These trucks always look good in orange. Can't wait to see it. You'll feel like a proud papa!
Jim
Old 03-12-2003, 03:30 PM   #12
dubie
dubie's Avatar
O already feeling that way just seeing this progress
