Old 01-20-2011, 12:35 AM   #1
weldvair@embarqmail.
Must II alignment with power steering
What alignment specs are you using for a AD truck w/a Must II IFS. The trk has a t-bird power rack.
I seem to remember 3 1/2 degree for the castor.....does this work?
Don
weldvair@embarqmail. is offline   Reply With Quote
Old 01-20-2011, 12:28 PM   #2
cajundragger
Re: Must II alignment with power steering
caster is driver preference.
3.5 would be fine, I usually set mine to 4-4.5.
cajundragger is offline   Reply With Quote
Old 01-21-2011, 06:30 PM   #3
T Hilde
You will want about 3/8 of a degree higher on the right that the left for caster. Camber should be 3/8 on the right 0 on the left. All this helps compensate for road crown gets it going straight.
T Hilde is offline   Reply With Quote
