Old 03-12-2003, 11:48 AM   #1
Mark540
4x4 vs. 2-Wheel Drive Frame ?'s
Is the frame in the front the same for the 4 wheel and 2 wheel drive models? I know that the crossmember to hold the suspension is different on a 2 wheel drive, but was wondering about the basic frame. I am thinking about some things, but it may not be practical. Thanks for your help.
mark
1970 GMC Burb 4x4 - 68 Chevy Front, FI LT1, 4L60E
1970 Chevy Impala 47,000 miles
2001 BMW 540i 6-speed
2002 Dodge Ram 1500 4x4 w/20's
Mark540 is offline   Reply With Quote
Old 03-12-2003, 02:29 PM   #2
Reumster
L.E.D. Freak
Reumster's Avatar
Yes the basic frame is the same just different holes/rivets installed. I took a 4X4 blazer and slapped a 2wd front crossmember under it. That should tell you. Just had to drill a few more holes for crossmember, and space the idler arm out from frame a bit.
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 03-12-2003, 02:38 PM   #3
Mark540
Thanks Reumster. That gives me another option to go. Any LED's for the Burbs yet, or will the truck ones work. I would like to do this mod sometime soon if available.
Old 03-12-2003, 03:29 PM   #4
Reumster
L.E.D. Freak
Reumster's Avatar
Yes the fleet side inserts work with Subs, you just need a peice of foam to make up for the extra room of the sub lense. Simple
(406)675-8082
Old 03-12-2003, 05:36 PM   #5
Mark540
Could you elaborate on the foam idea?
