71 bb longhorn
Bedwood finish 1/2 way done
Just finished putting the last of three coats of teak oil on the red oak hopefully this weekend I can start the first of three coats of spar for the finish.
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. Last edited by bc gman; 01-22-2011 at 05:54 PM. |
Re: Bedwood finish 1/2 way done
That looks real slick! Keep it up!
Rex |
Wow!!! Looks REAL nice!
Posted via Mobile Device |
69' Chevy Stepside
![]() Join Date: Mar 2008
Wow that is looking really good!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
chevy runs deep
Wow looks good
![]() Posted via Mobile Device
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
Florida Edition
![]() ![]() Join Date: Oct 2010
Could you please elaborate on the products you are using...mfg, etc.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
![]() Join Date: Aug 2007
Yes. More information please. I want to do mine. What was the last year a wood bed was offered?
![]() Robert 71 Chevy SWB |
71 bb longhorn
I am using Watco teak oil and General Paint spar varnish which is used for marine and other applications.
The first two coats of teak oil were mixed with thinners ( 10% thinner 90% teak oil ) and the last one was straight teak oil. I used 320 grit and sanded between coats. The next three coats will be spar varnish and sanding with 320 between coats. I will post some pics when I am done hopefully by mid next week.
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. Last edited by bc gman; 01-20-2011 at 05:12 PM. |
That looks awesome! I am just about to start my own, thanks for the specs on your project.
Trevor "You already said spite" |
It's all in the timing
Looking Good.
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
71 bb longhorn
Gobbles what are you using for your finish ?
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. |
Florida Edition
Which thinner are you using with the teak oil?
#13 |
71 bb longhorn
RenoKeene I am using mineral spirits for lacquers and varnishes.
#14 | |
thanks! |
#15 |
71 bb longhorn
Darkone - I am by no means an expert on this subject but by talking to different people and the internet this is what I came up with. As for different shades of teak oil I am not sure. varnish and lacquer are similiar but there are a few differences - lacquers come in clear & coloured, varnishes tend to be clear, the plasticizers in lacquer give it a more hard wearing finish than varnish.
As for the teak oil I used this as it penetrates deep into the wood pores and has good uv & moisture resistant properties and it is used often in marine enviroments above the water line. It also brings the grain pattern out in the wood. I wanted to protect the wood from the inside out and the spar will act as the exterior finish. I hope this helps but I am sure there are more qualified people on this matter other than me.
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. Last edited by bc gman; 01-21-2011 at 04:31 PM. |
#16 |
71 bb longhorn
Re: Bedwood finish 1/2 way done/before teak and after
A couple of photos showing the wood before the teak oil was put on.
