Old 01-20-2011, 01:45 AM   #1
alwaysbroken
Body lift?
long storey short the 2wd cab wont fit the 4wd trans in it. i need to get a body lift for it. do u know if a blazer body lift will work, its only for the cab. thanks
chevys the way to go.
alwaysbroken is offline   Reply With Quote
Old 01-20-2011, 02:03 AM   #2
jrdv
jrdv's Avatar
Re: Body lift?
It would be cheaper and easier to replace the floor board tranny cover with one from a 4x4. The 4x4's have a taller cover than the 2x's.
If you put a body lift on, it will change the geometry of the steering column, clutch rod ( if you have a manual trans ), radiater hoses, and it makes the truck a hair bit more top heavy.
john
jrdv is offline   Reply With Quote
Old 01-20-2011, 02:15 AM   #3
alwaysbroken
Re: Body lift?
thanks a lot for the quick reply. its a automatic and i was only going to do a 3 inch so i don't need to do the longer steering rod. but im going to do the body lift and a new trans tunnle so i know it will all fit. its always cool to have your truck a little taler lol. its a road truck anyways.
Old 01-20-2011, 02:28 AM   #4
jrdv
jrdv's Avatar
Re: Body lift?
I could be mistaken, but a 3 inch body lift will need to have the steering modified. I had a friend that did a home made body lift and he had to modify the steering rod. He also had to find another lower radiator hose ( the original rubs on the frame anyway ).
Old 01-20-2011, 03:13 AM   #5
alwaysbroken
Re: Body lift?
ok thanks for the help i will half to look into this. thanks i hope not to much has to be done.
Old 01-20-2011, 06:45 PM   #6
jakeblues652
jakeblues652's Avatar
Re: Body lift?
my truck has a 3" body, and the steering is fine. never extended. on the lower rad hose, i can't tell if its been replaced, but it does not rub.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 01-20-2011, 08:53 PM   #7
alwaysbroken
Re: Body lift?
sweet thanks man. i will update it when i get one.
Old 01-20-2011, 10:30 PM   #8
Trvr_lumsden
Re: Body lift?
I put a 3" body lift on a previous truck. There are some plastic plugs on the steering shaft you have to drill out and the shift linkage has to be extended. Buy a proper lift for your truck and it will come with very clear instructions. When you mark the tranny linkage, scribe it. I marked mine with a sharpie and it burnt off when I cut it. The kit will come with the peice needed to extend the linkage and it has to be welded.
1973 GMC 1/2 ton
1995 Chevy Tahoe
2002 Honda Shadow VT1100
Trvr_lumsden is offline   Reply With Quote
