Old 01-20-2011, 08:41 AM   #1
jasonroman
jasonroman's Avatar
trans slipping/??
well not sure if it is slipping or if problem is elsewhere.
from time to time, ill be driving at a steady speed. be it 40/45/55...either way, at a certain speed and maintaining that speed. and out of no where the truck revs up.
i know bad explination.
but when it does rev out of the norm, its quick. seconds.
for example if im doing 45 and if i had a tach, lets say it was at 3k at 45mph.
when the change comes about, i think i stay at 45 mph, but sounds as if rpms would go from 3k to 35-4k
agian, i know my explination is not too good. but thats what i notice happening.
not sure if its some sort of trans slippage or bad carb or what?
now reason id like to know problem is because i was recentley hit pulling into my driveway.
insurance only gave me 1800 to fix.
id like to take money and put into truck. but if i have a faulty trans or some major probs headed my way, i think i might look to buy another truck and put this one out back for slow but steady work.
thank for any kind of imput or suggestions
jasonroman is offline   Reply With Quote
Old 01-20-2011, 11:01 AM   #2
silvereagle07
silvereagle07's Avatar
Re: trans slipping/??
It could be slipping or the governor is sticking. I have seen this on a TH350 before. The next time it revs up "slips" put truck into neutral then back into drive. If the trans engages it's probally the governor. Good luck.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-20-2011, 11:11 AM   #3
James McClure
One shot, one kill.
Jason, What trans, what year? We need more info. Is fluid level ok and in good condition? Did it happen before you got hit? Could be several things from a minor detent or downshift cable issue (downshift switch\wireing on a 400) all the way up to major trans repair. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 01-20-2011, 11:55 AM   #4
jasonroman
jasonroman's Avatar
sorry to sound stupid here.
not sure trans.
not sure about fluid levels.
yes it did this prior to accident. got hit on the passenger side of bed.
damage is to bed side panel.
year is 1985
motor 5.7
trans maybe 700
square looking one.
Old 01-20-2011, 12:04 PM   #5
mooseknuckles
mooseknuckles's Avatar
check tranny fluid level,colour, and smell.
mooseknuckles is offline   Reply With Quote
Old 01-20-2011, 04:30 PM   #6
Keith Seymore
Keith Seymore's Avatar
Do you have a fan clutch on the engine driven cooling fan?
You could be hearing the fan engaging and disengaging as it maintains engine cooling (sounds like an airplane going by) - which is pretty normal operation. Engine rpm might not actually be changing.
Can you install a tach temporarily to verify that the engine rpms are actually flaring up?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-20-2011, 10:25 PM   #7
jasonroman
jasonroman's Avatar
not sure about fan. but im pretty sure its not fan related.
ill look to see if i can find a cheap tach and figure out how to hook it up.
Old 01-22-2011, 03:13 PM   #8
jasonroman
jasonroman's Avatar
well i might have another problem....
took a ride down the turnpike the other day. bout an hour ride south.
the ride down was smooth.
thought to myself, damn what a nice cruise at 75-80 mph.
maybe 2 hick ups on the way. but no biggie.
on the way home however...as i got back on the pike, i started smelling a burning smell...
no clue what it was or were it came from.
a little while later the smell went away, which was a good thing.
THEN
as im cruising at 70-75 ish. the truck suddenly starts to accelerate on its own. pedel headed south. like if i had cruise on.
but i did nothing to provoke this.
pedal just went south and stuck that way. eventually i braked off it and things turned back to normal.
why would that happen??
