Old 01-20-2011, 11:42 AM   #1
Fat Mike
Fat Mike's Avatar
Need Measurement for 59
What is the centerline of the rear axle in relation to the bumpstop on the bottom of the frame in the picture. Centerline looks to be 37 1/2" from the rear of frame.
Fat Mike is offline   Reply With Quote
Old 01-20-2011, 02:36 PM   #2
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: Need Measurement for 59
Mike,
I think I've seen that info here before and it might be 36", not sure. Maybe someone with knowledge can chime in here.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 01-20-2011, 05:49 PM   #3
Fat Mike
Fat Mike's Avatar
Come on guys. No one knows the answer? I just read it was 36.5 ". Is this correct?
Old 01-20-2011, 07:35 PM   #4
chevyrestoguy
chevyrestoguy's Avatar
I'll check mine when I get home. Remember, the rear axle will move in an arc when the suspension is compressed, so the bumpstop will be located farther aft than the centerline of the rear axle when the truck is sitting at ride height.
That measurement of 36.5" might be pretty accurate. That means that the rear axle moves approximately 1" to the rear when the suspension is fully compressed to the bumpstop.
Alex
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 01-20-2011, 08:36 PM   #5
hammerdog57
hammerdog57's Avatar
Mine is at 37" with no weight on springs. Centerline will probably move back about a 1/2" with all weight in place. I am using CPP lowering springs and brackets.
hammerdog57 is offline   Reply With Quote
Old 01-20-2011, 10:01 PM   #6
Fat Mike
Fat Mike's Avatar
Thank you guys for the info.
Old 01-20-2011, 11:29 PM   #7
Tchia65
Mines at 36 with a 4 link in a fleetside. Thats what no limit recommended to me.
1958 Fleetside shortbox
1965 Malibu SS
1970 Camaro RS
1972 Malibu wagon
Tchia65 is offline   Reply With Quote
