Old 01-20-2011, 01:49 PM   #1
Lemield
Lemield's Avatar
NAP Underdash A/C system Install
My Nostalgic Air Parts underdash A/C installation
I chose the underdash system because I like the retro look of it and I didn't want to change out my Chevrolet heating system.
The directions included with the kit are pretty decent but not very specific to a 1967-72 truck.
The kit was complete except for a template and a filler piece for the clearance cut that needs to be made in the stock heater box. It needs to be cut to clear the blower motor on the evaporator. I recommend that you call NAP if there is not a template in the kit. Mine had no template and I called. They sent me some black plastic but not what I needed at all...so...I made my own template and filler. NAP did not supply these parts....most likely because each installation is a little different. I used some very thin guage aluminum to cover the hole in the heater box and then I put the sticky backed foam tape over it. Works great and it is hidden from view after the new a/c unit is installed.
I removed my grille and my front bumper so I could work in the area a LOT easier. I suppose it could be done without removing the grille but I'm really glad I did. I also decided to install the LMC billet grille during this time. I think it looks really nice. The hood release they include is kind of hokey so I think I may convert to an inside cable release at some point. I drilled the 1.25 inch hole down low and to the left of the parking light wire hole. I will use the factory A/C line hole for the one of the hoses. I also drilled the two required firewall holes up by the blower motor wire. See pictures....
I had to remove my nice aluminium overflow bottle and go back to a plastic bottle on the inner fender. This is because I had the overflow mounted where the new A/C drier needed to go.
There was not enough #6 hose in the kit to make up the lines I needed. I will recommend to the supplier that they include 8 ft of hose for the underdash kit. The supplier should also include the high/low binary switch wiring harness and boot. They also should include two more 90 degree #6 hose fittings and two more grommets.
NAP was very good about answering questions and have stated that they will include more #6 hose and the fittings in their kits. Great customer service!
I had the A/C lines crimped at a great shop called Maxxair here in Denver. They charged me 2 dollars per crimp...a total of 16 bucks....and they look beautiful. I then installed and connected all the A/C lines. I put some PAG150 oil on the O-rings before assembling them.
Maxxair charged up the system for me last week and now it's
blowing ice cold air. Looking forward to using it in the summer months.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
