01-20-2011, 04:11 PM | #1 |
Stock Radio Cutout
Does anyone know if there is a template for the stock radio cutout? Mine was only cut a bit, so I think we're going to try to smooth the existing cutout and then cut a new one to the stock size. I can't justify buying an entire patch panel just to fix the small amount of metal that was cut.
Thanks! |
01-20-2011, 04:16 PM | #2 |
Hell yeah!!!
Re: Stock Radio Cutout
Run down to ur local junkyard and make a quick template. Other cars and trucks should have about the same size hole, granted their from that era.
Stock is good but custom is the sh*t! Last edited by nachodog2; 01-20-2011 at 04:19 PM. Reason: Wrong response |
01-20-2011, 04:32 PM | #3 |
If you still have the stock radio trace the face and stems...............for a template..........Hemmit
01-21-2011, 12:01 PM | #4 |
You could find a radio delete plate and run an IPod, I think the new Nano has an FM tuner also. See the attached thread.
http://www.jalopyjournal.com/forum/s...d.php?t=548824
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
01-21-2011, 07:54 PM | #5 | |
http://s1299.photobucket.com/user/jb...23904108567829 Last edited by jbgroby; 01-21-2011 at 07:54 PM. |
01-21-2011, 08:04 PM | #6 |
If worse comes worse, get youself a small piece of aluminum, cut and drill to fit your radio, but larger than the actual opening, buff it down and install as a face plate, I `ve done it on my last `65, sets off the radio.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
01-23-2011, 12:44 AM | #7 |
1961 crewcab
the 60 gmc is the wrong size shape, the radios changed to a skinnier wider face in 64...
I have a couple good dashes that I could get a template for you, or if you want to stop by next time you are in town..
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
01-23-2011, 09:13 AM | #8 |
Thanks everyone,
I'll go check at my local junkyard, or go visit Jon next time I'm in his neck of the woods. |
