01-20-2011, 04:30 PM | #1 |
gauges used in s10 swap? pics please
what gauge clusters are being used in the s10 swaps? what fits without modding the dashboard?
01-20-2011, 07:54 PM | #2 |
Re: gauges used in s10 swap? pics please
I went with a custom set from New Vintage (custom meaning I have km/h for driving in Canada)... Liked the old style look with the modern aspect. Made a set of adapter rings to set them off and they bolt right in. And an indicator set for my signal lights and shifts.
Cheers, Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
01-20-2011, 08:11 PM | #3 |
Maybe a dumb question... Can you use the original gauges?
Posted via Mobile Device |
01-20-2011, 08:19 PM | #4 |
The originals are all 6 volt, so maybe with some creative wiring and resistors. Or go to one of the aftermarket shops online and pick up the 12 volt repops and put them in the original faces....
Certainly ALOT cheaper than what I paid for mine... Don't ask... just don't ask... Cheers, Ted.
01-20-2011, 08:38 PM | #5 | |
Plus, if you're using a transmission made in the last 20 years it likely has a VSS not a speedo, so when you factor in the price of a cable-x box to run a speedo cable it doesn't seem as bad.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
01-20-2011, 09:47 PM | #6 |
here is mine stock speedo with sunpro guages and equus fuel guage for the s10 sending unit. not pretty but it'll work.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
01-20-2011, 10:58 PM | #7 |
AD Addict
You really only need a resistor to drop the voltage for the fuel gauge. You can use the rest if you really want to. The speedo is mechanical obviously.
If you search my name in a few places or Danimal, you'll find where I have a tech post on putting Autometer gauges in my son's '54. |
01-21-2011, 12:25 AM | #8 | |
I have priced those they dont give them away. I set down one night a drew up plan like 54 jimmy we will see...
http://67-72chevytrucks.com/vboard/s...d.php?t=413926 http://youtu.be/Qe9xJUhWkWc |
01-21-2011, 03:01 AM | #9 | |
01-21-2011, 07:08 AM | #10 |
I'd love to hang around your shop I bet I would learn a lot of cool stuff. I priced about $550 thats bad enough,right now I have the roadmaster dash setting on the column so we could get the turn signals to work.
01-21-2011, 09:34 AM | #11 |
any speedo cable recommendations, brand, length, compatibility with TH350. Jimmy i think that gauge cluster is pretty damn good looking. Thad...that is way to rich for my blood on gauges. They look great, but wow is that a chunk. for a rat I just can't spend it.
01-21-2011, 01:52 PM | #12 |
On my 54 I gutted the stock gauge housings and put crappy Dolphin 5" quads in place. You could can do the same with the 53 and earlier I would think. The 54 guages are a tad larger.
Just do not use Dolphin gauges |
01-21-2011, 03:27 PM | #13 |
I'm toying with the idea of running 67/68 Camaro factory gauges, possibly with white faces from an ebay kit.
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 Last edited by bretcopsey; 01-21-2011 at 03:28 PM. |
01-21-2011, 11:58 PM | #14 |
cool!!!
01-22-2011, 12:06 AM | #15 |
I think if they're 5" and you can find a quad setup, it would be a pretty damn good swap!
Great thinkin! Cheers, Ted.
01-22-2011, 08:04 AM | #16 |
Old Heap Driver
I'm planning to go with a quad setup, with an electronic speedometer in my '50. After installing a similar setup in my '73 I can't imagine not using an electronic speedometer. I spent no more than 10 minutes programming the speedometer and according to my GPS the speedometer reads within 1-2 MPH. No hassle with transmission gears, running speedometer cables etc etc.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
01-22-2011, 12:45 PM | #17 | |
01-22-2011, 12:55 PM | #18 | |
Old Heap Driver
Seriously though, yes, for mine which is the Dolphin brand, it was a piece of cake. The instructions said to drive a measured mile and select a "start" and "end" feature with the programming button. I drove my then daily driver that had a trip meter to measure out the mile. There was no speed requirement so I measured a mile from the end of my street to the mile point. I went back home, hoped in the truck and drove the mile, it was that simple. I checked my newly programed speedometer against my GPS and it was darn near spot on. I'm sold on them. At some point I'm going to replace the mechanical AutoMeter unit in my S-10 with an electric one. Any future speedometer purchases will be electric as well.
01-22-2011, 06:40 PM | #19 |
AD Addict
Yep. Autometer tells you to do 2 miles. It ended up being the mailbox at one end of my road to a stop sign at the other end. You hit the button, start driving at 45 mph (if you can) and then stop and hit the button again. I had my son follow me in my DD, set it, and then I tried to keep up with him on the way home. It was dead on all the way up to 85 mph. We just didn't tell his mom...
Here is a post I did a while back on the swap: http://www.jalopyjournal.com/forum/s...d.php?t=269446 Last edited by Dan Bowles; 01-22-2011 at 06:45 PM. |
12-18-2011, 07:23 PM | #20 |
Does anybody know where i can find gauges that will plug in to the s10 wiring harness ?????
