Old 01-20-2011, 08:38 PM   #1
BamaDave
holley carb prob(pics)
what part is it that is leaking in the picture? this is at the bottom right front of the carb. also why is there all the discoloration around the front?
BamaDave is offline   Reply With Quote
Old 01-20-2011, 08:46 PM   #2
fattyarbuckle
Re: holley carb prob(pics)
accelerator pump
^^SP
I'd say fix the leaks and clean it and the coloring should stop.
fattyarbuckle is offline   Reply With Quote
Old 01-20-2011, 09:03 PM   #3
BamaDave
when my truck is idleing, you can smell fuel, so it is running really rich. The idle rpm is @1000, any less and the thing wants to die. what kind of adjustment should I try?
Old 01-20-2011, 09:08 PM   #4
fattyarbuckle
fix all the leaks first and then look for vacuum leaks...it should idle down more than that.
Old 01-20-2011, 09:20 PM   #5
mooseknuckles
mooseknuckles's Avatar
looks like the gaskets on the metering block and the accelerator pump are leaking!
mooseknuckles is offline   Reply With Quote
Old 01-20-2011, 09:23 PM   #6
BamaDave
Where would b the best place to pick up parts?
Old 01-20-2011, 09:44 PM   #7
cableguy0
You need a rebuild kit. That carb is leaking from everywhere. Thats whats causing the discoloration. Generally a super rich and rough idle in a holley is a blown power valve. The power valve will come in the rebuild kit.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-20-2011, 10:19 PM   #8
benoit454
Chris
benoit454's Avatar
summit, jegs, advanceauto or autozone all have rebuild kits. I would 2nd the rebuild front could be the bowl or metering block/plate, side is the accelerator pump, could be the base to the body gasket also.
Idle speed should be around 800rpms in park warmed up to temp. and about 600 rpm in gear.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 01-20-2011, 10:26 PM   #9
66skylarkpost
66skylarkpost's Avatar
you could just give all the screws a turn , how old is the carb ?
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 01-20-2011, 10:40 PM   #10
BamaDave
about 10 to 12 yr. old
Old 01-20-2011, 10:40 PM   #11
allengator
allengator's Avatar
Adjusting a leaking carb won't help... If gas can leak out, air can leak in under vacuum...
+1 on the rebuild kit!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 01-20-2011, 10:46 PM   #12
66skylarkpost
i know the newer plastic bowl screw gaskets always could use a tightening once in a while . yet since its that old and hasnt been gone thru , i'd overhaul it .
Old 01-20-2011, 10:49 PM   #13
allengator
allengator's Avatar
My bad... I was thinking you meant adjusting screws!!
Allengator
Outta the Blue
Old 01-20-2011, 11:27 PM   #14
BamaDave
I've never rebuilt a carb before but I am willing to try. Or should I not even attempt this. I'm somewhat mechanically inclined. How much does a kit cost and should I get any extra jets, pump cams, etc.? Also, what causes the powervalve to pop?
Old 01-20-2011, 11:35 PM   #15
66skylarkpost
dont be intimidated . holleys are simple , a simple rebuild is easy . it looks to be a 600 vacumn secondary , it keep it stock . a power valve will come the kit and holleys in the last 15 years have a anti blow-put orifice in the base plate and rare blow one , all it is a small diaphram . a rebukld kit for that will run around $30 , have a couple cans of carb cleaner and patience . the kit wil come with instructions, an exploded view and a float gauge . if you need help, you can find it on this board .
Old 01-20-2011, 11:40 PM   #16
cableguy0
Power valves can wear out due to age and crack. They will also blow or pop from a backfire through the carb. Theres no need to change any jets or pump cams etc. Just leave it be and install the rebuild kit.
