Old 01-20-2011, 10:24 PM   #1
avysittinon22s
avysittinon22s's Avatar
Decided to step notch my frame and more
Decided to just get my rear level with the front. Frame rails are 2x4x3/16, wanted abit heaver so it would ride better. Trailing arms are 2x2x1/4 with adjustable bushings.
Rusty driveshaft is just for mock up right now, pulled from a junkyard since I needed a smaller diameter.
Everything will be fully welded, grinded and smoothed before painting.
avysittinon22s is offline   Reply With Quote
Old 01-20-2011, 10:28 PM   #2
avysittinon22s
Re: Decided to step notch my frame and more
more
Old 01-20-2011, 10:34 PM   #3
avysittinon22s
more
Old 01-21-2011, 12:38 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
Looks good! I never knew your truck didn't sit level...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-21-2011, 01:28 PM   #5
4x4fab
I like the holes.... I'll prolly be doin a lot of flared holes with my chopped and bagged 64' build.
4x4fab is offline   Reply With Quote
Old 01-21-2011, 10:20 PM   #6
avysittinon22s
thanks guys, its coming together slowly
Old 01-21-2011, 11:51 PM   #7
scotts62
One day...
scotts62's Avatar
Looking good!
Scott
93 crew cab build
Project 62
Old 01-22-2011, 10:49 AM   #8
jlaird
jlaird's Avatar
I like the speed holes. My advice though would be to use them sparingly, dont go crazy with too many, everywhere...
jlaird is offline   Reply With Quote
Old 01-22-2011, 12:19 PM   #9
67cheby
67cheby
67cheby's Avatar
looks awesome
67cheby is offline   Reply With Quote
Old 01-23-2011, 11:27 AM   #10
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
What are you using for a trailing arm? They look pretty small.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 01-23-2011, 07:41 PM   #11
avysittinon22s
2x2 square 1/4 thick
Old 01-23-2011, 11:05 PM   #12
firedog
firedog's Avatar
looking good you need to come visit up this way some time
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 04-20-2011, 10:40 PM   #13
avysittinon22s
slowly coming together all wiring, air line and fuel line routed thru the frame
Old 04-20-2011, 10:42 PM   #14
avysittinon22s
more
Old 04-21-2011, 08:12 AM   #15
DZL1
One day.....
DZL1's Avatar
Man that looks nice!!!
DZL1.
DZL1 is offline   Reply With Quote
Old 04-21-2011, 08:35 AM   #16
Pop's C-10
Pop's C-10's Avatar
nice work
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-21-2011, 09:54 AM   #17
lakeroadster
Man you do good work, fabrication and painting looks awesome.
I wanted to mention that the strength of the 2" x 2" x 1/4" trailing arms is marginal.
The analysis I ran is based on the air bag seeing a 1500# load (the approximate weight of the truck at the rear axle). This assumes all the weight on one bag (realistic shock loading from pot holes, speed bumps, etc.).
Safety Factor for the 2 x 2 x ¼” tubing is 0.86.
In comparison, a stock trailing arm Safety Factor, also using 1500#, is 3.0.
I don’t want to be a “buzz kill” but felt compelled to mention this.
If the air bag wasn't monted on the 2" tubing it would be just fine as a ladder bar, the weight on top of such a relatively small section height structural member is the problem.
John
lakeroadster is offline   Reply With Quote
Old 04-21-2011, 09:54 AM   #18
67cheby
67cheby
67cheby's Avatar
Clean work looks SMOOOOTH
Old 04-21-2011, 09:43 PM   #19
avysittinon22s
John
Well i guess ill find out, ive seen a few built with 2x2. I wasnt asking about the strength though
Old 04-21-2011, 10:02 PM   #20
Mkcustums
Mkcustums's Avatar
What your using it for should work, just watch since they are mounted off to the side that they dont start to bend too much.
...and btw, it looks awesome painted!!
Mkcustums is offline   Reply With Quote
Old 04-22-2011, 08:14 AM   #21
lakeroadster
Just trying to help ya and others here on the board too.
I'd rather say something so you can keep an eye on it, as opposed to it failing and leaving you scratchin' your head along the highway somewhere.
There are also a lot of fabricators on our site that base there future or current builds on what they see here, this allows them to consider using something more substantial than the 2" x 2" x 1/4".
Sorry if my post offended you.
John
Old 04-22-2011, 05:03 PM   #22
Mkcustums
Mkcustums's Avatar
↑↑↑ I think it was a very valid point to make, don't feel bad about what you said, it's just the truth. I've seen you make comments like that before and it's helped others out!
Old 04-22-2011, 10:54 PM   #23
bedsled71
bedsled71's Avatar
looking good
bedsled71 is offline   Reply With Quote
Old 04-22-2011, 11:48 PM   #24
Mkcustums
Mkcustums's Avatar
Is the frame painted from the cab forward? If so you should put some pics of that too. I'm not a big fan of red, but I like the way that looks!
Old 04-23-2011, 01:26 AM   #25
nastyc10
nastyc10's Avatar
looks really nice man!
nastyc10 is offline   Reply With Quote
