Old 03-12-2003, 01:31 PM   #1
19mike69
modulator valve leaking?
my mod valve seems to be leaking right where it goes into the side of the transmission....how do you fix this?....mine seems to twist from side to side,are they supposed to do that?....any help will be appreciated
19mike69 is offline   Reply With Quote
Old 03-12-2003, 01:39 PM   #2
71-longbed
Its Magically Delicious
71-longbed's Avatar
sounds similar to how mine is.... i put a hose clamp on it ... im not sure how to trouble shoot if it's gone bad .... mine had lots of oil around it...sorry i couldn't help more
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 03-12-2003, 07:47 PM   #3
JimKshortstep4x4
Talking
There is an "O" ring that seals the part of the mod body that slides into the transmission. It is pretty easy to change the "O"
ring. If you jack your truck up on the passengers side it will move the transmission fluid to the drivers side and minimize the amount of fluid you lose. (Always use stands under the truck).
There is a clamp held on by a 5/16-18 bolt with a 1/2" hex head.
Remove the bolt and clamp and the modulator will slide out. I always put a pan under the mod as some fluid will come out.
Remove the modulator, replace the "O" ring and lube the "O"
with transmission fluid and reinstall.
When you pull the vacuum line off, if you see any oil in the metal tube, you will want to replace the modulator.
Jim
Old 03-12-2003, 08:34 PM   #4
19mike69
Jim...thanks alot....thats exactly what i needed to know....im guessing you can get this O ring at any parts store?
Old 03-12-2003, 08:38 PM   #5
19mike69
hey,i have another question....on the drivers side on the radiator support that runs all the way across the fron,there is a bolt on either side of the radiator on the bottom....on mine,the bolt on the drivers side is loose but the top of the bolt is round like a carriage bolt....how the hell do you either replace that or tighten it?
Old 03-12-2003, 09:11 PM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
19mike69..the carrige bolt is in a 1"x1" flat piece of steel with a square hole in it. That will keep it from turning. Hold down on the head to keep it from poping up. Good luck finding a 7/16 carriage bolt.
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 03-12-2003, 09:41 PM   #7
JimKshortstep4x4
Talking
Mike,
If the parts store is a problem most transmission shops will help you out.
If you know someone in machine maintenance, they usually have a selection of "O" rings and would probably give you one.
Jim
Old 03-13-2003, 08:41 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
In addition to replacing the O-ring, clean the area well with brake or carb cleaner and put a bead of RTV around the part that goes into the transmission (above the O-ring) before installing. This will help seal it better.
If there is any sign of transmission fluid in the hose, the modulator is bad and should be replaced.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
