01-21-2011, 05:39 AM | #1 |
68 and 69 cab question
Hey guys my buddys grandpa has a clean 69 Chevy that's missing the rear end the cab is solid I wanna know if that 69 cab will fit my 68 frame and bolt up to my 68 fender,grill bump hood and radiator support?
Posted via Mobile Device Last edited by ATrain707; 01-21-2011 at 05:40 AM. |
01-21-2011, 06:26 AM | #2 |
Re: 68 and 69 cab question
The fuse box on the 67-68 is different than 69-72 fuse block and it used a pull handle for emergency brake instead of a foot operated emergency brake, these 2 things will cause problems. You'll need to use 69 engine harness & forward lamp harness if you use the 69 cab and you'll need to change to the foot operated emergency brake. If the 69 is complete you can most likely use its wiring harness's if good and its emergency brake setup.
Paul @ GMCPauls |
01-21-2011, 06:47 AM | #3 |
ok. would the bed,doors,and whole front clip off the 69 fit on a 71? and would doors off a 71 fit a 68?
01-21-2011, 06:52 AM | #4 | |
Paul @ GMCPauls |
