Alignment specs for drag racing
Do you guys have a particular alignment specs you use for dragging. Its a 71 c10 LWB factory arms for now!
71 C10 2WD,472 Big Block Buick B4B Intake,800 cfm Q-Jet built by(Fred Catlin) Comp Cam 254/268@ .050 .530/542 lift 1 7/8 supercomp headers, 2 1/2 X-Pipe/ Magnaflow's Mallory fuel system Igniter Flame thrower Ignition system TH350,Hughes 3500 Converter ,3.73's Its just an old heap, but its my hot rod! |
Registered Truck Offender
Re: Alignment specs for drag racing
All I do is jack the front up an inch and a half or so, and set it to stock spec (or as close as they can get) It is on the street so seldom any more that getting a ' track' attitude for top end control is the priority.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
I typically have them jack it up 1.5" then get as much caster as possible, 0 to .5 degrees of camber and 1/8 total tow...
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
Dead at work today so we put it on our new hunter alignment rack. Camber is 0, caster 3.4 and toe is .09.
Had to take back shims completly out to get caster to rise, but 3.5 seemed the most we could get and keep some camber adjustment. Ordered a Afco & QA1 catologs. I understand the front spring requirements, but how do you determine the rear spring rate ? Thanks Cooter
