01-21-2011, 05:12 PM | #1 |
Need to slam my doors shut; HELP NEEDED!
I've been trying to figure this out....
My C10 has had it's body pretty much restored, but somehow I need to slam the doors too hard to get them closed properly. 'The doors don't sag. And there's nothing else as far as I can see or feel that appears to be wrong with it. I know most of these trucks don't have doors that shut as nice as a new Lexus. But a friend of mine has a '90 Suburb which has really nice closing doors......they simply click onto the doorpin. Do I need to grease the locks? Or is it something else?!?!?.
1972 GMC 2500 Sierra 350 1971 Pontiac LeMans Sport 400 GTO/Judge Clone 1970 Pontiac GTO 400 convertible restoproject 1970 Pontiac Bonneville 455 convertible Last edited by erikgto; 01-21-2011 at 05:16 PM. |
01-21-2011, 05:47 PM | #2 |
Re: Need to slam my doors shut; HELP NEEDED!
have you tried adjusting the latch on the door, and if I remember right the pin on the cab is adjustable also.
01-21-2011, 05:49 PM | #3 |
lube and adjust the latch. It made a huge difference on mine.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
01-21-2011, 06:06 PM | #4 |
Try it with the window down and see if it's better.
Those doors are light and they push a lot of air. The relief valves in the cab cant' vent the air fast enough, particularly with a regular cab (that's why a Suburban can be better - because it's got more internal room to compress the air). Mine got much worse after I replaced the door seals. I usually keep my door open while the passenger closes his/her door, then close mine after them. You can take the Pressure Relief Valves our of the bottom of the doors and that will sometimes help; the tradeoff is you will get a bit of cold air through them during the winter. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-21-2011, 06:07 PM | #5 |
Look at the door striker and see if the plastic bushing is distorted. Replace it and adjust the striker.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
01-21-2011, 06:07 PM | #6 |
Rottenwood Garage Member
Do you have the plastic round things on the stricker studs?
You may need to replace or ad them.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
01-21-2011, 06:43 PM | #7 |
I agree with 72 freak those plastic sleeves on the door strykers make a huge difference.
"WIDER IS BETTER" (TRUCKS ONLY) |
01-21-2011, 08:46 PM | #8 |
it may sound weird but have someone put your truck up on a lift, mine did the same thing but after i put er up on the lift it shuts a lot better now
1979 Chevy C10 Longbed |
01-21-2011, 08:46 PM | #9 |
If the doors are difficult to close & rattle, it's usually related to the striker bushings. If they don't rattle, try the window down strategy & see if there's improvement (since it was 'pretty much restored', that might mean is has fresh door rubber/seals).
01-21-2011, 09:04 PM | #10 |
BAD BOW-Silverado XST
Crack your window a bit. Check the flap not the passengerside kick panel. It should be open a bit when the heat is off.
Posted via Mobile Device Posted via Mobile Device |
01-22-2011, 05:00 AM | #11 |
All rubbers and seals are new.
I'll try the styker first. And lube the vents.
1972 GMC 2500 Sierra 350 1971 Pontiac LeMans Sport 400 GTO/Judge Clone 1970 Pontiac GTO 400 convertible restoproject 1970 Pontiac Bonneville 455 convertible |
01-22-2011, 10:00 AM | #12 | |
Then go from there. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-22-2011 at 10:07 AM. |
01-22-2011, 01:42 PM | #13 |
[QUOTE=erikgto;4429460]All rubbers and seals are new.
I would say thats your problem. My front doors need a slam, and I could not get the rears to even latch, so I went to the local Pick and Pull and grabbed the rear set out of a newer burb and now they shut like a Caddy. I will change the fronts when I change the doors. Darren
67- 72 Parts collecter |
01-22-2011, 02:15 PM | #14 |
01-22-2011, 02:39 PM | #15 |
Unbolt the post from the back, and the large washer unscrews and the plastic slides off.
Remember the position of the post so you can put it in the same spot.
67- 72 Parts collecter Last edited by classicchev; 01-22-2011 at 02:41 PM. |
01-22-2011, 03:19 PM | #16 |
Mark it w/a sharpie before loosening/removing.
01-22-2011, 08:58 PM | #17 |
My 75 does the same thing even with new doorhinge pins/bushings and the window cracked open. I will check the striker. Didnt know they had a bushing? News to me.
01-22-2011, 10:36 PM | #18 |
you might need to remove the rear speakers on the 86 to access the back of the striker panel area... and grab a couple extra plastic bushings for future replacements
1986 LWB C-10 305/th400 Daily Driver and beer runner |
01-24-2011, 05:44 AM | #19 |
Also remember when you remove the striker bolt that the threaded backing plate will now fall down in the pillar. This is a real treat to deal with when doing the front doors of a crew cab or a Suburban. You basically have to take all the trim out in that area to do it. ANOTHER GREAT GM DESIGN!!!
