Old 03-25-2002, 02:08 PM   #1
old_truck1969
old_truck1969's Avatar
Post speedometer question
I've got an '86 GMC that was making a horrible clicking sound. I changed the speedometer cable, and the noise stopped. So i figured all is well. Now, i only get a clicking sound when it really cold out and i am above 70 km/h (about 45 mph). Once the truck warms up completely, the noise stops. I only changed the long cable from the speedomteter, not the short one that threads into the tranny. Should i change the short one? Should i have greased the new cable?
What did i do wrong?
69 GMC 3/4 ton camper special(very long term project)
86 GMC 3/4 ton (daily driver)
Thunder Bay, Ontario, Canada
djbonazz@hotmail.com
"All Corvettes are red. The rest are mistakes." - John Heinricy
old_truck1969 is offline   Reply With Quote
Old 03-26-2002, 12:22 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I would remove both cables and squirt some heacy oil in there and see what happens.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-26-2002, 07:26 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Talking
I had a similiar problem. I removed the two piece cable and installed a single type cable from the speed to the tranny. I took out the rotating cable and greased it really light with some wheel bearing grease. My speed over reads when its cold but quickly drops to normal operation after a few miles.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-27-2002, 10:47 PM   #4
72MARIO
72MARIO's Avatar
Post
Hey I had the same problem in my 87 Burb I let it squeek for a couple of weeks then one cold day it was super loud it just started to spin in circles . When I took it apart I found there is a spring behind the needle that was all twisted up Ended up going down to the wreckers getting a whole spedo form a 85 and put the odometer form the burb which reads 426000 into the speedo from the 85 Oh the needle wil break the shaft off really easy trust me I did it putting it back together! Down to the wreckers to get another one ! All good now I am from around
Newmarket Ontairo .
72 Chevy 350 1\2 leaf springs soon to have ps, pb, 700R 2/4 drop , 88-94 bench ,67 front clip ,Blazer tank flip down tail light gas filler
Filled stake pockets minor smoothing to fire wall and Frame shortened.posible idea of ash tray into cup holder?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
