NEED HELP! I've got a BIG REAR (drums)
short story:
ive got a BIG DRUM '72 c10 rear and wondering if i can use later model brake parts on it since i cant find new '72 big brake parts...??? long explanation: '72 c10 rear and just found out that it has the BIG REAR DRUMS! 11-11/32 x 2-3/4" rather than 11x2" problem is i need the drum and EVERYTHING inside it and i am only finding parts for the 11x2.... (only BIG thing i find is shoes) i notice that later models are bigger and share the same 2-3/4" width but the diameters are 11-5/32 (6/32 smaller) since i need everything... i am wondering if i can use everything from a later model as long as it is all matched up? anyone tried this? PO had put 11x2 stuff on it and didnt realize that he was only using 1.25" of his 2" shoes!!! yikes... i was like WOW when i open it up! |
Re: NEED HELP! I've got a BIG REAR (drums)
hmmmm
i wonder if this means that ECE is already doing this??? (bottom) http://www.earlyclassic.com/catalog....upgrade%20kits |
20' Daredevil (Ret)
![]() Join Date: May 2003
Can't answer your question, sorry -- but here's a thread from a while back. It may have some info that will help you find the parts you're looking for.
http://67-72chevytrucks.com/vboard/s...d.php?t=419077
thanks Stocker.
i read that one (along with about 50 others) before i posted. im having a hard time believing nobody else has had this issue! LOL mayne I'm the only one who thinks it is an issue! ;-) i guess i could take backing plate to drum off of a 70's donor but i think i would rather just weld new perches on the donor! ha! |
anyone got ideas sunday eve?
thanks! |
Watch out for your cornhole !
![]() Join Date: Jun 2003
You need to buy parts for a 72 Suburban to get the larger brakes. It's a glitch of the parts system that they don't list the 2 3/4 brakes for pickups, only Suburbans. I have been through this before on past trucks.
I had written an article in the past with pictures showing the differences.
http://67-72chevytrucks.com/vboard/s...d.php?t=187552
#8 | |
Happy to be here
![]() Join Date: Mar 2000
Active Member
![]() Join Date: Jun 2002
you can also change to newer model stuff, everything is bolt up look for a truck with the JB5 brakes.
http://67-72chevytrucks.com/vboard/s...d.php?t=370561
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
Ha! I was waiting for you to chime in with the answer Tx Firefighter! LOL And you did!
Thanks so much! You might want to change your name to GMencyclopeia! Thank you as well Zeke. I have an '80 and was pondering just that. |
PS... i SWEAR i searched first! TX, great write up! Many thanks!
Happy to be here
That post is now an FAQ- LINK
