View Poll Results: Steel or Polyethylene Fuel Tank?
Steel 9 47.37%
Polyethylene 10 52.63%
Voters: 19. You may not vote on this poll
Old 01-22-2011, 10:07 AM   #1
2badgn
Poll: Steel fuel tank or Polyethylene fuel tank and why?
I might have to replace the fuel tank in my 1984 GMC Sierra 3500 Single rear wheel 2wd Pickup. It has one fuel tank and I think its a 16 gallon.
What are the advantages and disadvantages of steel fuel tanks and Polyethylene fuel tanks?
2badgn is offline   Reply With Quote
Old 01-22-2011, 10:44 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Poll: Steel fuel tank or Polyethylene fuel tank and why?
steel will rust out in 20 plus years... polyethelyne is not as strong and more expensive... ID stick with stock. In our area advanced sells em cheapest and you can upgrade to a 20 gallon without any hassle.You will need to locate the proper fill hoses but the rest just works out fine ive done this before
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-22-2011, 12:09 PM   #3
GM72K10
Next!
GM72K10's Avatar
Why do you think its a 16 gallon? They were only available on shortbed pickups that year Even the duel tank option was for 2 20 gallon tanks unless you had a shortbed i.e. CK10703 then it was two 16 gallon tanks.
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 01-22-2011, 02:12 PM   #4
2badgn
My truck is at the shop now but I will measure the tank. I thought it was a 16 gallon bc of the gas receipt from the service station but then again I dont know if the gas gauge is 100 % accurate.
Old 01-22-2011, 05:16 PM   #5
edge
edge's Avatar
Polyethylene....1/4" thick! I have two, they been doing fine for years.
edge is offline   Reply With Quote
Old 01-22-2011, 07:27 PM   #6
rayfinseats
steel will rust out in 20 plus years... poly will rust out NEVER.
rayfinseats is offline   Reply With Quote
Old 01-23-2011, 01:56 AM   #7
andrewmp6
I like poly they are used a lot in newer cars and trucks they are thick and hard to put a hole in it.
andrewmp6 is offline   Reply With Quote
Old 01-23-2011, 02:07 AM   #8
cableguy0
poly doesnt rust. safety isnt a factor. Every manufacturer uses poly tanks in new cars. The nhra allows poly tanks in drag cars. I would go poly.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-23-2011, 03:05 PM   #9
donut
donut's Avatar
I voted and went with the poly. I believe the cost difference was about 20.00.
At least that's one thing I won't have to worry about rusting out.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 01-23-2011, 06:14 PM   #10
snapdaddy
where do you get a Polyethylene fuel tank at
snapdaddy is offline   Reply With Quote
Old 01-23-2011, 07:02 PM   #11
lakeroadster
Here is another thread, same topic: http://67-72chevytrucks.com/vboard/s...d.php?t=282017
Originally Posted by Chevyholic View Post
I say steel. Depending on the mfg process of the poly there is a chance that all of the additives in the new gas can eat away at the inner lining and cause you fuel pump issues. I had a poly tank a few years back and I went through 5 fuel pumps before finally just replacing the poly tank and no more fuel pump issues. The lining was coming up and clogging the fuel pump until it stopped working. Serious PITA.
It goes without saying that I'm sure there are many people out there that have been running them for years without issue, but I'll never go back.
Originally Posted by crews View Post
I vote steel.
I had put a poly tank in my 72 crew cab and I wasn't very pleased with the fit nor did I like how easily it was distorted.
Originally Posted by Classic Heartbeat View Post
Polly or steel, it is up to you. However the poly tank is a lot tougher than the steel tank. Polyethylene tanks are produced from extreemly tough cross linked polyethylene. Polyethylene by itself is impervious to everything but fire. Even battery acid doesn't penetrate it and Cross linked Polyethylene is extreemly impact resistant!! MTS (The poly tank manufacturer) makes the tanks to twice as thick as DOT requires them to be, so believe me when I say it can take a big impact without rupturing. The hottest heat of the Desert South can not warp it. (Unless it hit more than 400 degrees or hotter!!) Anyone who has warped a tank, either didn't have it vented correctly and it only warped temperately while under suction pressure, or parked it over a fire. Most of your new cars all have poly tanks now and they are holding up just fine. Actually they hold up better than steel, because they do not rust!! They do not have a protective liner inside because they do not need one. Unlike steel to keep it from rusting.. Do what you want, but my vote gets poly!! (And I do sell both) WES
lakeroadster is offline   Reply With Quote
Old 01-23-2011, 09:25 PM   #12
S10Fan
Old Heap Driver
I say plastic. The fuel we buy isn't going to get any better, the plastic will never corrode due to junk gas.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-24-2011, 06:26 AM   #13
andrewmp6
http://www.gmcpauls.com/fuel_tank_related1.htm
Old 01-27-2011, 12:50 PM   #14
Goldfinger
Goldfinger's Avatar
Steel all the way. They won't melt or puncture. The rust issue can be controlled by occasionally topping off the tank.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
