01-22-2011, 12:27 PM | #1 |
67cheby
looking for billet wheel polishing tips
any certian brand of polish, any polishing tips, any coating ideas for after the polish
01-22-2011, 01:08 PM | #2 |
Re: looking for billet wheel polishing tips
here's an awesome article on the basics of billet wheel polishing
01-22-2011, 01:09 PM | #3 |
One word Flitz. It is expensive but you can polish anything with it.
Kerry
1969 Chevelle 1990 IROC Z Convertible 2002 Silverado LT |
01-22-2011, 01:11 PM | #4 |
67cheby
thanks for everyones tips , keep em coming
01-22-2011, 01:34 PM | #5 |
Flitz is what Street and Performance in Mena, Arkansas uses on their engines trannys, and other billet parts. That is what I use to polish my engine (LT1) and Weld Pros Stars. (Which I need to do before I pull it out of the garage again). You do the old Weld Wheels up and don't have to polish them again for a few months.
Kerry
01-22-2011, 02:16 PM | #6 |
most billet wheels need thier original finish clear coat or whatever stripped b4 any polishing can b done
01-22-2011, 04:36 PM | #7 |
Billet wheels typically don't have any clear coat on them. Clearcoats are typically on the high production cast type wheels.....Eagle, American Racing, etc.....
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
01-22-2011, 05:31 PM | #8 | |
Tot Roddin'
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
01-22-2011, 05:48 PM | #9 |
67cheby
great article
01-22-2011, 07:35 PM | #10 |
it looks silly, but you would be amazed at the finish you get by "buffing/rubbing" the compound with nothing more than your finger ...
01-22-2011, 07:52 PM | #11 |
There is a message board on this site specifically for this topic. It's called "detailing".
01-22-2011, 09:18 PM | #12 |
smith brite
01-23-2011, 12:33 AM | #13 |
Parts and more parts
If you have a set that is really dirty, then there is a way to clean them without a lot of elbow grease. I use what is called razor buffs on a die grinder, with a polishing brick to clean the metal and get the polish started. A razor buff is usually a 3' or 4" buffing wheel that can be attached using a pointed tool on the die grinder. It is easy to get into tight spots and cut the metal to get the smooth finish started.
I use Mothers aluminum polish with a power ball to get the next step going and then finish with Mother's Billet polish to get the mirro finish. I then seal the metal with a metal sealer from one of a couple sources, to keep the road dust and dirt out of the pores. I usually do my wheels twoce a year to keep them clean. Looking at the attached write-up, I di remember some of the older guys using flour, but had not approached that thought in many years. I think that will be my next trial going into this coming spring.
Frank |
01-23-2011, 01:59 AM | #14 |
Junior Member
Use a product called Mothers Billet Wheel Polish. Use a soft terry cloth, fold into a small thick square and polish with the grain of the wheel. If you rub in a circle motion you will create swirls which means lots more work. Always continiously refold cloth or replace. Another tip is to use some spray detail like Mothers Quick Detail on the cloth you intend to remove the polish and this help lift the polish without scrubbing and again remove with the grain of the wheel.
Regards, Perry PTS
Great Deals for 67-72 members on Billet Specialties, Intro Wheels, and Ridetech! Toll Free 1-855-353-7885 |
01-23-2011, 03:19 AM | #15 |
Flitz, nothing else needs to be said
Mike Redpath |
01-23-2011, 03:29 AM | #16 |
C/10 CLUB MEMBER
They look *****in...but they are a ton of work....good article though...thanks for posting.
-Ron- |
01-23-2011, 03:46 AM | #17 |
TILT COLUMN GURU
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
01-23-2011, 10:08 AM | #18 |
I use a German product called Autosol. It's a paste thats been around for a while. It's available at some E-bay stores. Great stuff!
01-23-2011, 10:30 AM | #19 |
Mike I own a detail company and have tried a million products for all the custom cars and the custom bikes we do. The best thing I have found so far is called white diamond found at some auto parts house. I start off with the power ball then move to hand polishing with a latex glove on my hand. Sounds silly but it makes a diff. When your done it will be like A mirror.
Juan Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
01-23-2011, 11:12 AM | #20 |
Active Member
I get ticked off every time I see one of those guys at a swap meet talking about how great the Mothers Powerball is. It might work if you have completely smooth wheels, but forget it if you have anything with spokes, like polished Torq-Thrusts. Mine didn't even last a day before it started shredding little bits of foam all over my wheel, then it came loose from the stem that holds it in your drill. I will never go near another one, even if it is free.
On the other hand, I have been using a Flitz Ball for three years now with glorious results. It is about the same price as the Mothers ball, maybe a little more, but it is well made, washable, and it is a product that works. Highly recommended.
1957 GMC Ambulance 1962 Belair Wagon 1963 C80 Truck Cab *FOR SALE* 1969 Chevy C10 Short Bed 1972 Chevy C10 Long Bed *SOLD* 1996 C3500 Dually *SOLD* Last edited by 7T2; 01-23-2011 at 11:16 AM. |
01-23-2011, 11:43 AM | #21 | |
Frank |
01-23-2011, 12:29 PM | #22 | ||
Tot Roddin'
01-24-2011, 11:22 AM | #23 |
67cheby
great info from everyone, Thank you and keep it up if anyone else has any more tips
