Old 01-22-2011, 01:11 PM   #1
Leadfoot Lambert
Leadfoot Lambert's Avatar
driveshaft question
Should my 65 short c10 use a 1 or 2 piece drive shaft? There is a 1 piece drive shaft that came with the truck but I'm not sure if its right. Any help is appreciated.
Leadfoot Lambert is offline   Reply With Quote
Old 01-22-2011, 02:05 PM   #2
javadoc
Hey Watch this...
javadoc's Avatar
Re: driveshaft question
Hmmm, my short stepside has a 1 piece unit.
What have I gotten myself into now?
1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress
2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids
javadoc is offline   Reply With Quote
Old 01-22-2011, 02:23 PM   #3
Indian113
Indian113's Avatar
My 64 short has a 1 piece.
Indian113 is offline   Reply With Quote
Old 01-22-2011, 02:33 PM   #4
Leadfoot Lambert
Anyone happen to know the correct length? And thanks for the help, I'm feeling better about this already!
Old 01-22-2011, 03:07 PM   #5
padresag
what makes you think that it is not right?
ron
padresag is offline   Reply With Quote
Old 01-22-2011, 03:26 PM   #6
enick72
enick72's Avatar
I think that the 2 peice shaft is only for the 4 speed because there is no slip yoke.
55 Chevy 1st series
65 Chevy stepside short bed
www.bigslikpokertables.com
enick72 is offline   Reply With Quote
Old 01-22-2011, 04:13 PM   #7
nachodog2
Hell yeah!!!
nachodog2's Avatar
2 piece drive shaft are found in longbeds, you my friend need a 1 piece.
Stock is good but custom is the sh*t!
nachodog2 is offline   Reply With Quote
Old 01-22-2011, 04:25 PM   #8
javadoc
Hey Watch this...
javadoc's Avatar
Long beds. My truck has a 4speed... one piece driveshaft.
Old 01-22-2011, 04:40 PM   #9
1enick72
1enick72's Avatar
Is it a SM420? (Super low 1st gear) mine is a short step that had this tranny with a 2 peice shaft that I swapped out for a T5 and a 1 price shaft.
1enick72 is offline   Reply With Quote
Old 01-22-2011, 05:23 PM   #10
Leadfoot Lambert
I just bought this truck, it's my first early Chevy truck and the only clues as to what it had for a drive train are a rusty set of sbc headers and a one piece drive shaft that were in the bed along with a bunch of garbage, there is no clutch pedal so ill assume it was an automatic. Also does anyone have a picture of the trans cross member, and tranny mount setup? what should be there for motor mounts? Plans are for a Chevy v8 and a th350 which brings up one more question, what length tailshaft th350 do I need? I have a short one under the bench.
Old 01-22-2011, 05:35 PM   #11
padresag
you will determine the length of your d/shaft when you get the rest of your running gear in. your old shaft may fit or it may not. why not give us a picture of what you have in the transmission area for crossmembers now in order that everyone doesn't have to speculate on what you have or haven't gotten as you cannot tell us to much
ron
Old 01-22-2011, 05:53 PM   #12
Leadfoot Lambert
Here ya go
Old 01-22-2011, 06:10 PM   #13
padresag
it was orig a std trans and someone put in an a/t. that crossmember back there is where the rear of the tran was mounted. i don't know how those frt perches work . chev or gmc?
ron
Old 01-22-2011, 06:13 PM   #14
Leadfoot Lambert
its a Chevy, how can you tell it was a standard?
Old 01-22-2011, 06:25 PM   #15
padresag
quite easily. the bellhousing crossmember is gone. one can see the different colour inside of the frame rails and you can see where the lazy bastards just cut it off at the top of the frame rails.. that is not the sdt a/t rear crossmember that is there and looks like some bracing for something was scabbed into the inside of the frame rails in frt of that trams c/member. need any more
ron
Old 01-22-2011, 08:41 PM   #16
Leadfoot Lambert
Should I just buy something like this instead of messing around?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old 01-22-2011, 08:50 PM   #17
Indian113
Indian113's Avatar
that would cover all the bases, CPP is a vendor on the site. I would check with jeff and see what he can do for you! Check out our Vendor list
Old 01-22-2011, 09:04 PM   #18
padresag
nothing wrong with whats there. I don't know what that other crap is that is welded onto your frame is for though
ron
Old 01-22-2011, 09:11 PM   #19
Leadfoot Lambert
The rear crossmember in the pic is just bolted on, it looks kinda like a trans crossmember from a 73-87 Chevy truck. if I was to stick with what is there for motor mount brackets would I use the clam shell style motor mounts?
Old 01-22-2011, 09:16 PM   #20
padresag
http://www.persh.org/pickup/IdeaPage.htm
Old 01-22-2011, 09:27 PM   #21
Leadfoot Lambert
Thanks! lots of good info there, but like you said those frame brackets don't look right, Is it possible my truck had a v6 from the factory?
Old 01-23-2011, 12:37 AM   #22
padresag
perhaps you have a chev body on a gmc frame. coils or springs in the back. if it is a chev there should be a matching ser# on the top of the frame in the area of the str box.
these trucks see a lot of changes over the years by people in their backyards due to accidents and so on. you nmever know until you really check it out
ron
Old 01-23-2011, 10:29 AM   #23
Leadfoot Lambert
It has a coil spring rear suspension, so it should be a Chevy chassis. It is so true about parts being swapped around, so far I have found several 1960 parts on my 65 like the grille,and tail lights and maybe even the whole bed, I still haven't figured out if the front suspension has been swapped or if someone just swapped the spindles as it has 5 lug disc brakes up front. As soon as the snow lets up a little I will check the vin number on the frame to see if it matches the cab.
Old 01-23-2011, 03:42 PM   #24
padresag
there was the odd gmc with coils; believe that it was optional
ron
Old 01-23-2011, 10:12 PM   #25
Leadfoot Lambert
I decided to buy the above kit and save the hassle, and I saved $140 over buying the parts individually
