Old 03-21-2002, 01:57 AM   #1
trukman1
Post 80 TH400 Torque Converter-Bolt Size?
Picked up a 1980 (supposedly) TH400 and the torque converter bolts were missing. Installing 3/8-NC bolts by hand seemed loose. Tried to insert 10mm tap, also by hand, and it seemed to fit better. Did GM switch to metric bolts in the 1980 versions, or at all? Or do I have a different year? Thanks for any help, Gary
1967 K30 461/TH400/Np205/D60/14FF/BDS
MTZ 375/75/16 on 16x10 Pro Comps
trukman1 is offline   Reply With Quote
Old 03-21-2002, 07:32 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Talking
The VIN number will tell you the model year. You do have round headlights right? If they are square then its an 81 or newer model. I don't know when GM went to metric bolts on some items. I know some bolts on my '83 are metric. I'm pretty sure the converter bolts are too. Best bet is to buy converter bolts from a catalogue. The bolts need to be very strong to hold the flextplate and torque converter together. You can get bolts from www.jegs.com www.summitracing.com
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-21-2002, 11:14 AM   #3
trukman1
Post
Problem is I don't have the VIN just bought the tranny from a guy who said it was out a 1980 truck. I bought bolts from Jeg's that were too large for the holes in the flexplate I got from Summit...Go Figure! Will call a tranny shop today and will post findings later.
Old 03-28-2002, 03:17 AM   #4
trukman1
Post
Turns out they're 10mm! Yech! And I wanted to keep it all SAE. Fellow I used to work for owns a tranny shop now and he's getting some for me. He said '80's can be either. Go figure.
