Old 01-22-2011, 04:34 PM   #1
67sss
67sss's Avatar
wire id please
just got a 72 highlander and am going thru the engine bay. I know green wires are usually temp wires(the one on the left), any ideas what the other 2 wires are for? There's a temp sending unit on each side of the block. First pic of sending unit is on pass side other is on drivers side. I'm just trying to get engine to run or start, after a compression test,fresh oil, new gas, plugs ect... before I decide whether to keep the truck or part out. Thanks
67sss is offline   Reply With Quote
Old 01-22-2011, 05:11 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Re: wire id please
Green is Temp, Greasy one is for oil idiot light, the other with the flat plug is ????? how many wires Two or Three?
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-22-2011, 05:11 PM   #3
Firefighter
Re: wire id please
Did or does it have a/c?
Yellville, Ar. USA
Old 01-22-2011, 05:24 PM   #4
67sss
67sss's Avatar
Re: wire id please
no a/c, didn't have it. 3 wires.
Old 01-22-2011, 05:39 PM   #5
Firefighter
Re: wire id please
Turbo 350 or 400?
Yellville, Ar. USA
Old 01-22-2011, 05:48 PM   #6
67sss
67sss's Avatar
Re: wire id please
350 tranny- M49 on the spid sheet. 400 tranny has a square pan, right?
Old 01-22-2011, 05:50 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: wire id please
Probably one of the TSC relay connectors. TSC was a crude emissions device that retarded the ignition spark in relation to engine vacuum. It came out in 70 or 71 IIRC.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-22-2011, 05:51 PM   #8
john
member #16
john's Avatar
Re: wire id please
The one on the pass side head is a switch for the TCS (transmission controlled spark) Only allows vacuum advance in high gear and when up to operating temp. It has usually been removed from most trucks that had it by now.
john is offline   Reply With Quote
Old 01-22-2011, 05:53 PM   #9
67sss
67sss's Avatar
Re: wire id please
VetteVet- This set of wires is in the original harness and is located in the rear of the dist. area, it won't pull over that far. Thanks tho!
Old 01-22-2011, 05:59 PM   #10
Firefighter
Re: wire id please
TCS transmission controlled spark hook up, I'd say thats why there are 2 temp senders also.
Yellville, Ar. USA
Old 01-22-2011, 06:00 PM   #11
Firefighter
Re: wire id please
some had the relay up kind of behind and to the side of the dist. also.
Yellville, Ar. USA
Old 01-22-2011, 06:06 PM   #12
67sss
67sss's Avatar
Re: wire id please
ok. THANKS! now lets hope for a good compression test!
Old 01-22-2011, 06:12 PM   #13
sameyrasmea72
sameyrasmea72's Avatar
Re: wire id please
I agree with the others above, it is for the TCS or TSC stuff. That is why there is two temp senders. One for the guage and the other is for the TSC. I found some paper work that explains what id does and how it hooks up but I can't find it.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 01-22-2011, 06:24 PM   #14
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: wire id please
Google
http://arrc.epnet.com/autoapp/8977/8...ed_Spark__.htm
VetteVet
