01-22-2011, 08:44 PM | #1 |
man what is it with the body gaps on these trucks i am pissed!
i love these trucks with all of each years faults and goodies but for the life of me i cannot get the lower passenger fender to move forward it is so bad i cant open my door it always does this i have some patience believe it or not but i am now to the point were i am ready for it to be fixed and for it to do its job which is stay were i tell it to!!!!!
01-22-2011, 08:52 PM | #2 |
Re: man what is it with the body gaps on these trucks i am pissed!
Rick, i know i have, and feel sure most of the guys on here have been in this situation..
i know u have heard the line .."walk away from it... do something else, and come back to it later"....... this helps sometimes...
01-22-2011, 08:57 PM | #3 |
69' Chevy Stepside
I hear you, my truck had issues like that when I was assembling it after it had been apart for close to 5 years. It takes a lot of patience to get it right sometimes, what I would try is to use a Portapower or a small bottle jack to "push" the fender forward from underneath, then bolt it on to hold it forward.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
01-22-2011, 09:03 PM | #4 |
thanks matthew i will try this tommorow
01-22-2011, 09:08 PM | #5 |
i dont wanna make another thread so i will just ask on here ,how do i get a dog dish hub cap off of a 6lug steele rim from my dads 70 4wd???!!!!???!!??!!??!!
01-22-2011, 09:09 PM | #6 |
try adding/removing some shims on the front passenger side cab mount between the bushing and underside of the truck..
01-22-2011, 09:12 PM | #7 |
there is nothin but the mounts there and if i ad sme then it will get worse
01-22-2011, 09:35 PM | #8 |
Does your dad have a lamb's paw (nail puller),some call them cat's paws. That is the best tool,other than a hubcap removal tool,I have found.
01-22-2011, 09:41 PM | #9 |
67-72 parts collector,…
You hi-jacked your own thread?
01-22-2011, 09:45 PM | #10 | |
I would try loosening the core support to frame bolting. Also loosen all the fender bolts front and rear. (maybe even the inner fender rear bolts) The fender will come off the truck,... so it will also move forward. If your truck has frame damage, that might have to be addressed before you start elongating bolt holes.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-22-2011 at 09:46 PM. |
01-22-2011, 10:18 PM | #11 |
'67 C-10 LWB Driver
'67 C-10 LWB - My Build Thread '67 C-20 LWB - My Donor/ Parts truck - SOLD! '92 GMC SAFARI VAN - My Parts Go Getter '06 KIA SPORTAGE EX - My Commuter "All of this crap better make a truck!" - my wife Sue. Proud U.S.M.C. Dad! |
01-22-2011, 10:23 PM | #12 |
Grandpa in the rustmobile...
oh no! lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-22-2011, 10:26 PM | #13 |
01-22-2011, 10:29 PM | #14 | |
01-22-2011, 10:29 PM | #15 |
01-22-2011, 10:36 PM | #16 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
"Lowlife" hit the nail on the head...Loosen the core supports and the fender bolts at the core support, that should give at least 3/8" forward slop. PS. Bend the last inch or so of a large screwdriver at a 90 degree right angle and you have a hub cap puller.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 01-22-2011 at 10:41 PM. |
01-24-2011, 12:06 AM | #17 |
These frames definitely flex. With the lower rear fender bolt loose, try jacking up just the front right frame horn as far forward as you can(as close to the front bumper as you can get your jack). I think you will see that lower gap open up. Tighten up the lower bolt and lower the truck back to the ground. You should have your desired gap.
Brett |
01-24-2011, 12:56 AM | #18 |
RAT1968 '68 Cab/'71 Parts
I believe I saw one for sale at the Home Depot in A t w a t e r for just under $870.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
