01-22-2011, 09:11 PM | #1 |
Air Conditioning
Does anybody have any good/bad experiences with putting A/C in their trucks? I'm starting to look around here and haven't found any threads. Pics, as usual, would be appreciated.
-MG
1951 Chevy 3100/S-10: http://67-72chevytrucks.com/vboard/s...d.php?t=406072 1957 Chevy 3200 1971 2WD Blazer - Sold |
01-22-2011, 09:16 PM | #2 |
Re: Air Conditioning
Theres some in the project section that have AC in them.
01-22-2011, 11:08 PM | #3 |
I used a vintage air kit made for 47-53 trucks. It is a pretty nice set up. If you are using a aftermarket bulkhead, getting the hoses set up on the inside can be tricky. Attached are some pics of a friend of mine that put in a similar set up in a suburban.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-23-2011, 12:17 PM | #4 |
I have the Vintage Air on both of my AD's and they will cool your cab with LOTS of insulation.
There is enough room to place 4 hoses in the space between the kick panel and Cowl and hide all of your hoses under the wheel well.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
01-23-2011, 12:21 PM | #5 |
All service parts of the A/C are in reach without adding more connections (leaks)
01-23-2011, 05:54 PM | #6 |
That is a very clean setup.
01-24-2011, 07:00 PM | #7 |
I just installed a Old Air Products bolt in unit in the panel I'm buildingnow. I use a Hot Rod Air in the 47 Pickup. No problems with either.
01-25-2011, 09:36 PM | #8 |
we use Vintage in everything we build, no problems, cools great
01-26-2011, 10:30 AM | #9 |
I'm looking at the rear unit from Suburban, Tahoe etc. Factory engineering is hard to beat, replacement parts are available at the local parts store, and what I have found listed on eBay are cheap compared to the aftermarket companies.
For example: http://cgi.ebay.com/ebaymotors/ws/eB...%3AMEWAX%3AVRI
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 |
01-26-2011, 02:26 PM | #10 |
how would you run the controls on the tahoe unit?
01-26-2011, 02:57 PM | #11 |
Those rear units have their own control panel. I'd find a way to mount it where it couldn't be easily seen.
http://cgi.ebay.com/ebaymotors/03-06...Q5fAccessories Ideally, I want to find a donor vehicle that I can pull the HVAC unit, control, wiring etc. as a complete system.
01-26-2011, 04:24 PM | #12 |
Like the glove box?
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
01-27-2011, 10:00 AM | #13 |
Perhaps. Though that seems like it could be a little cumbersome. I've thought about mounting the center trim on a hinge and building a recessed panel behind that, or on the front of the seat riser, in the middle...
I'm no where near that stage yet though.
01-27-2011, 12:18 PM | #14 |
Just my opinion. Oem systems are built for that specific model and are usually harder to make work in a different vehicle. For the amount of time and work you will have in it you might as well of ordered a kit from Vintage Air. They offer direct bolt in kits for these trucks or you can put a custom kit together the way you want it. Just trying to keep things simple should pay off in the long run. Good luck with your project. We are building a 49 for my son and will be using the Vintage Air Sure Fit Kit for these trucks. Their price is $1150.00 for a whole kit but you can probably find a better price from a vendor on this forum.
Never a failure, Always a lesson! 1968 Chevy SWB Fleetside ECE 4/6 327/350 1987 Chevy V20 Scottsdale 4X4 350/400 4.10 1987 Chevy Custom Deluxe SWB 305/7004R4 1991 Suburban Silverado V1500 4X4 350/700R4 2015 Chevy Crew Cab SWB (Daily Driver) 5.3 |
