Old 03-12-2003, 06:57 PM   #1
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Progress pics, 70 swb
finally I will post some progress pics.
I finally got the correct spindles for 1.25" thick rotors.
just put the spindles,springs, upper and lower control arms, rotors, calipers, pads, and front shocks on.
finally its back on all 4 wheels, its alot eiasier than rolling it with the floor jack holding the front of the truck.
i got all of my steering parts, paint dring on them right now.
anyway heres some pics, in the garage.
tommie is offline   Reply With Quote
Old 03-12-2003, 06:59 PM   #2
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
another
Old 03-12-2003, 07:01 PM   #3
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
last one
Old 03-12-2003, 07:26 PM   #4
TxGary
TxGary's Avatar
Looks good Tommie, keep us posted with the progress.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2015 Chevy Tahoe LTZ 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 03-12-2003, 07:29 PM   #5
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
nice keep up the good work
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
Old 03-12-2003, 08:00 PM   #6
Myride
Good work.
Myride is offline   Reply With Quote
Old 03-12-2003, 08:16 PM   #7
ol skool 68
turnin wrenches
ol skool 68's Avatar
looks good man!!
"three can keep a secret if two are dead" -unknown hell's angel-
D.M.C. -FF-
68 SWB full frame off (project ol skool)
2000 s-10 formally bagged but now my daily driver...
ol skool 68 is offline   Reply With Quote
Old 03-12-2003, 09:39 PM   #8
racedvl
racedvl's Avatar
Looking nice, what type of paint did you use on the frame?
racedvl is offline   Reply With Quote
Old 03-12-2003, 10:01 PM   #9
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
thanks for the compiliments,
as far as paint goes, I ground down all the surface rust,
applied about 2-3 coats of rust oleum rusty metal primer,
then used rustoleum satin black (7777)
I used this paint on my 82 gmc when i did the suspension and dropped it, and it worked good, and it is relativly inexpensive also.
i get it at Home Dpeot, they have it in rattle cans or by the quart.
tommie
Old 03-12-2003, 10:47 PM   #10
casey
casey's Avatar
tommie looks like your doing it right, Love to see it finished, how do you walk around your truck, your garage looks like mine.
casey is offline   Reply With Quote
Old 03-13-2003, 12:31 AM   #11
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
your right,
no room to walk around truck in garage,
step 1 is to pull truck out of garage into driveway for anything.
thats why i am so glad to actually have wheels on the front of it again, it was a lot harder rolling it out with it on the floor jack.
rolling on tires is much easier.
all of my steering linkage is dring outside right now.
will be nice to have all the tie rods, center link, and idler arm back on.
it feels good to make progress.
tommie
Old 03-13-2003, 01:19 AM   #12
brad2
Progress pics are my favorites. The front looks great!
brad2 is offline   Reply With Quote
Old 03-13-2003, 11:55 AM   #13
case_bt
case_bt's Avatar
looks good did the tierod adapters go together alright.
case_bt is offline   Reply With Quote
Old 03-13-2003, 01:31 PM   #14
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
the tie rod adapters seem to work ok, have not fully installed them yet, test fit one side, took back apart to paint tie rods and idler arm.
will know for sure this weekend.
the 70' outer is used as an inner, because it has reverse threads,
it is what makes the sleve work.
tommie
Old 03-13-2003, 02:45 PM   #15
case_bt
case_bt's Avatar
yep it also makes it so that you can use the stock 70 centerlink
Old 03-15-2003, 12:51 PM   #16
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Thats going to be a sweeet truck when ur done !!!!!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-15-2003, 01:04 PM   #17
71-longbed
Its Magically Delicious
71-longbed's Avatar
agreed looks like its going to be a great truck
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 03-15-2003, 02:26 PM   #18
frost89434
frost89434's Avatar
Looks very good. I used the same paint on my frame.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 03-15-2003, 03:13 PM   #19
lunatic
lunatic's Avatar
Looking good,keep the progress pics coming....
lunatic is offline   Reply With Quote
