Old 01-22-2011, 10:28 PM   #1
Indy72
16.5 Wheels & Tires
I traded for some 16.5 aluminum slots,the fronts are 9'' and the back one's are 10''.My truck(C-20 2wd)has 16.5 steel wheels with 8.75x16.5 tires on it,are these tires too narrow for these wheels?Any opinions on what tire size would look the best? Thank's
Indy72 is offline   Reply With Quote
Old 01-22-2011, 11:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 16.5 Wheels & Tires
measure the tread width of the tire. It should be pretty close to the rim width. The taller the tire, the more forgiving it'll be.
I've run too narrow of a tire on a wide rim, they were tall enough to take up the slack. It looked stupid and handles like crap, but no real issues
Old 01-23-2011, 01:19 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
This is an old rule of thumb that still holds true.
For more specific recommendations, check tire manufacturers' web sites or http://www.tirerack.com/.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-23-2011, 07:12 AM   #4
Are you sure the wheels are 9 & 10"? The 10 sounds right,it's actually 9.75. But,I've only seen those and 8.25s. The thing with 16.5 tires is they are low profile by their own nature,unless you get into big off road tires. They were created in the "Wide Oval" era when these trucks were made. I always ran 9.50s on 8.25s.
Old 01-23-2011, 09:54 AM   #5
Indy72
So what size would look and handle the best?
Old 01-23-2011, 10:43 AM   #6
9.50s on front and 12.50/33s on rear. The 8.75s might be ok.It's only 3/4" narrower and still wider than the wheel...if it's 8.25.
Here's a '71 C/20 I had with the sizes I suggested:
