Old 01-22-2011, 10:43 PM   #1
yellowGT
yellowGT's Avatar
rear big wheel question
On a 67-72 truck, what is the widest wheel you can run without having to get rid of the trailing arms? Wheels in mind are 22x12 with a 4 inch backspace. Narrowing the rearend is something I dont mind and know it will have to be done more than likely. You guys let me know so I can relate the info. to my brother.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 01-22-2011, 10:54 PM   #2
c10seconds
c10seconds's Avatar
Re: rear big wheel question
Ive got 22x12 in the rear with ride tech trailing arms and there is tons of clearance. I do have a mini tub but even with stock arms you should have plenty of room.
c10seconds is offline   Reply With Quote
Old 01-23-2011, 04:12 AM   #3
mwilliams5891
can I see?
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56
-03 Mazda Protege 5
-WTB 1970 Chevelle project
mwilliams5891 is offline   Reply With Quote
Old 01-23-2011, 05:33 AM   #4
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Mine has 15x10's and pretty big rear tires and its really close to rubbing on the inner fender/bed, with stock rear trailing arms and lowered with springs and a adjustable trac bar.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-23-2011, 11:21 AM   #5
Hart_Rod
Hart_Rod's Avatar
I'm running 20 x 12's with a 7" backspacing and a 31-16 tire. I'm not anywhere close to the trailing arms. Here'a few pictures:
Hart_Rod is offline   Reply With Quote
Old 01-23-2011, 12:15 PM   #6
QKENUF4U
QKENUF4U's Avatar
if you tube it you can run a 15x14 - 10" bs w/ 31x18.5 tire and still clear the arm.. not sure how big ya can go if you keep the stock tubes....
QKENUF4U is offline   Reply With Quote
Old 01-23-2011, 02:17 PM   #7
c10seconds
c10seconds's Avatar
Quick question... What kind of fuel tank is that??
Old 01-23-2011, 02:55 PM   #8
Hart_Rod
Hart_Rod's Avatar
I had a buddy make it for me. It's similar to the ones that FuelCell guy sells, but we modified it to have the sump in the back.
Old 01-23-2011, 03:08 PM   #9
67chevy1series
67chevy1series's Avatar
wow that last pic sholud be in a frame and sent down to me!
67chevy1series is offline   Reply With Quote
Old 01-23-2011, 03:30 PM   #10
mwilliams5891
is the stepside really different from the fleetsides?
-03 Mazda Protege 5
Old 01-23-2011, 08:44 PM   #11
c10seconds
c10seconds's Avatar
pics so you can see the 22x12
Old 01-24-2011, 02:09 PM   #12
c10seconds
c10seconds's Avatar
I like it!
Old 01-24-2011, 02:31 PM   #13
short-t
short-t's Avatar
Rob I LOVE that truck! I was wondering, does it still has the narrow rear end?
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD.
1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc
short-t is offline   Reply With Quote
Old 01-24-2011, 05:16 PM   #14
Hart_Rod
Hart_Rod's Avatar
Thanks, it's got a factory 68 rear end.
Old 01-25-2011, 12:43 AM   #15
Bulldog88
What do you have to do to be able to run a 22x12 with a 4 inch backspace?
Bulldog88 is offline   Reply With Quote
Old 04-08-2011, 03:36 PM   #16
mac808
mac808's Avatar
Hart_Rod and C10Seconds, do you guys have any rubbing issues on the fender(outer) side of the tire?
mac808 is offline   Reply With Quote
Old 04-08-2011, 05:50 PM   #17
Hart_Rod
Hart_Rod's Avatar
I had slight rubbing when I had the wider 71/72 rear installed. None whatsoever with the narrower 67-70 rear end.
Old 04-09-2011, 05:36 AM   #18
c10seconds
c10seconds's Avatar
Same here. Im using the 67 rear end and there is no rubbing at all
Old 04-09-2011, 06:35 AM   #19
mac808
mac808's Avatar
Sweet! I shouldn't have a problem stuffing in a wide wheel in the rear on my '68 then!
Thanks for the feedback guys!
Hey C10, any more pics of your truck with the 22's like in your avatar...?
