Side Marker.....Turn Signal?
Was wondering is anyone has converted side marker lights so they would work as a turn signal as well?
Did a search but came up empty.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
KEEP ON TRUCKING
ive seen it done i think by running a wire from the hot signal wire to the hot sidemarker wire.repeat on all 4 corners.i think this is the way i was told havent done it
72 cheyenne 2wd lwb 71 k20 sons bassett va |
Would you loose your side marker lights if you wire them to the turn signal wire, or would it just make it blink when the turn signal is on?
If done right, it would be just like the front turn signals.
With the lights on they would be running lights...... Using the turn signals they would be that............. Has to be wired and use the same 1157 bulb for the front turn signals....
its all about the +6 inches
You have to remember, some of these trucks did not blink on the front side markers. I have had 2 70 longhorns, neither had hacked harnesses, yet one blinked, the other does not.
The rear never blinked on any of them. To make a front marker blink (asuming it does not) You need to run the ground wire from the marker light to the turn signal wire at the front marker light. (parking/turn signal light) When the turn signal is off, the wire will act as a ground, but when it is powered, it interupts the ground, making the side marker blink oposite the front turn signal. To get the back side marker to blink, you would need to run a wire from the front to the back and wire it the exact same way. If you hooked it up to the rear light, the side marker would go out every time you hit the brakes. |
Well, I know somebody was playin around in my wiring, and when I hit the turn signals or 4 ways, the front marker lights flash. But also, when I hit the brakes my rear sidemarkers lite up too.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
just tap the hot wire from the turn signal ti the marker light really easy to do
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Turn Signals
I did mine, not a hard task at all. I have a 1972 and all I did was run 2 wires down the inside of the frame rail. One from the front driver side marker, to the rear driver side marker, use that wire as your power to your rear light. Repeat this on the other side and bang. No problems at all. I have parking lights all around and turnsignals. I think it looks sweet with the rear blinking to match the front.
Cliff
1972 Custom deluxe 305/350 C/10 8-foot bed with 1/4 inch diamond plate steel bed floor. |
