Old 03-12-2003, 07:38 PM   #1
78customdeluxe
Unhappy 700r4 trouble
i think that my 700r4 just crapped on me. it takes forever to shift and it only shifts into 3rd gear at about 85mph. then i can slow down to cruising speed and then after a while it will shift into 2nd again. tried adjusting and readjusting the tv cable but made no diffrence. i changed the oil and filter about 200 miles ago and it ran good right after that till i went to town yesterday. i think it needs a rebuild so how much do you think would be reasonable for a quality kit for me to rebuild it myself and where to get it at. thanks.
88 Crewcab Dually 5.9 Cummins, 5306 Eaton 6-speed, converted 4x4 w/52's up front, 90 front clip(parting out)
1986 ElCamino (needs motor)
1970 C30(future service truck for my ag-equipment repair business)
1970 CST10(parting out and partial donor for the '70 C30)
2000 GMC 1500 ext cab sb, z71, 5.3 loaded auto
78customdeluxe is offline   Reply With Quote
Old 03-12-2003, 07:50 PM   #2
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Before you go too crazy, take the governor out and see if the plastic gear is worn away. This has happened on two of my 700R4's and after replacing the gear one of them is still going strong 15000 miles later.
The governor is behind the round cover on the driver's side at the rear of the tranny (on the side, not in the pan).
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 03-12-2003, 08:43 PM   #3
78customdeluxe
how hard is it to get that out? do you loose any oil when you take the governor out? what is the part number for that gear if it needs replaced? id just like to know before i get in over my head while its in my barn getting worked on by myself before i go to my cousins and have him work on it. something i forgot to mention earlier is that when i block up the rear end and put it in overdrive it will shift just fine then if that makes any diffrence at all? thanks
Old 03-12-2003, 09:00 PM   #4
ElGracho
ElGracho's Avatar
Once the cover is off, the governor just slides out.
You will lose about 2 ounces of ATF when you take the cover off.
I don't have the part number off hand, I can get it.
If the gear is bad it will be apple cored, like this:
Joe
Old 03-12-2003, 10:37 PM   #5
78customdeluxe
well i went out and checked that but the gear was good yet. now i didnt loose any oil at all when i did it. and it didnt seem like there was any oil in the governor valve very recently anyway. so would anyone have an idea on what it might be then? check ball in the valve body? throttle valve sticking? im open to suggestions.
