01-23-2011, 11:09 AM | #1 |
68 camaro headers on my 66 stepside
I'm in the process of installing a 350ci bored .030. And the heads and cam like bigger tube headers.
I have some new 1968 camaro Headman Hustler headers 1-3/4 tubes. with 3" collector. My truck is lowered by the jeep coils in rear and cut coils in front. So I dont think ground clearance is a issue. Also Im running a Saginaw 3speed with overdrive. Any of you guys know if this will work?
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
01-23-2011, 11:13 AM | #2 |
Re: 68 camaro headers on my 66 stepside
I run a set of summit LT's from a 67-81 camaro with my automatic and had to trim about 1/2" off the pass side rail to clear the header tube. On a stick truck I dont know how they will play with the linkage. Mine are 1 5/8 tube also.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
01-23-2011, 11:30 AM | #3 |
yeah i have some Long tube that are 1-5/8 that have been on my truck for a long time.
I guess Ill just have to try the camaro ones and hopefully do very little mods.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet Last edited by NCD1966; 01-23-2011 at 12:36 PM. |
01-23-2011, 12:31 PM | #4 |
It should work and not hang below the frame much
01-23-2011, 11:51 PM | #5 |
60-66 Nut
You will likely have clutch linkage and bellhousing crossmember interference.
01-24-2011, 06:03 AM | #6 |
When I installed long tube headers on my 64 with a 3spd I had trouble with the clutch linkage not fitting. I had to rotate the z-bar back(towards the front of the truck) a ways to clear the last primary and make a new rod from the pedal down to the z-bar. if you go this way just remember to leave adjustment in the rod to fine tune your pedal to clutch travel. When you change the rotation of the z-bar it changes how much it pushes on the clutch fork. If not done correctly you end either with short pedal travel and possible slipping clutch or not enough travel to disengage the clutch completely.
