01-23-2011, 03:44 PM | #1 |
Window regulator, restore or replace?
Windows don't roll up/down worth a crap on my blazer. Should I buy new regulators or restore the old? if the answer is restore what's the steps? sandablast/bush/paint/etc?????
Thanks, David |
01-23-2011, 04:23 PM | #2 | |
Re: Window regulator, restore or replace?
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
01-23-2011, 04:44 PM | #3 |
i'd actually spray the heck out of them with wd40 first to clean out any petrifried crap then once clean and working well i'd spray them with the lithium grease to lubricate for a prolonged lifespan
01-23-2011, 04:53 PM | #4 |
454 MAKES IT ROAR
Cleaning & lubricating is fine, but if the small plastic wheels which roll up and down the channels are worn...and lets face it after forty odd years of use!!!
I replaced mine.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
01-23-2011, 04:59 PM | #5 | |
Hope that helps Paul
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
01-23-2011, 05:04 PM | #6 |
Grandpa in the rustmobile...
Heard 'new' regulators are crap and break, I think sinister had this problem?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-23-2011, 05:05 PM | #7 |
10-4 thanks guys, gotta love this place!
01-23-2011, 05:34 PM | #8 |
I would check the weather stripping that goes down the door frame and down through the long brace in the door. They tend to break up and keep the window from sliding like it should. Also the long vertical weather stripping on the vent window. The fuzzy stuff comes off and blocks the glass from working good. Most of the regulators I have seen work fine if you clean/grease them AND CLEAN OUT THE TWO GROOVES that the glass slides in.
72 Cheyenne Super 80 Silverado Blazer 2wd |
01-23-2011, 05:39 PM | #9 |
454 MAKES IT ROAR
Finding a set of original regulators that have not been rolled up and down much in their life would be rare as rocking horse s**t, when I took mine out to clean and lube I discovered that one of the plastic wheels on the PS had seized at some point in the past and worn itself flat on one side with continued use, the drivers side which sees the most use had all the wheels worn smaller with rolling up and down rusty channels which made them prone to fall out of those same channels. My replacements have been in and trouble free for nearly 3 yrs now, I'd say these parts are only as strong as the little plastic wheels on the ends of the regulator arms.
01-23-2011, 06:35 PM | #10 |
ive had my new window regulators in for about a year now and have had no problems with them. they're great
WITNESS Dont be like me be better than me |
01-23-2011, 07:02 PM | #11 |
I am a Referee of life.
I've been using the same repop window regulator for about 10 years.I do keep it and the tracks lubed but don't really see any reason to complain about the repop.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-23-2011, 07:09 PM | #12 |
Between Trucks...
Yeah, I'm searching for a solution before it gets too warm here. Repop from Classic Parts died after a couple of years. PanelDeland do you remember where you got yours?
Beat it to fit, Paint it to match... |
01-23-2011, 07:40 PM | #13 |
I agree! first clean the regulator & lube it up. On some I've had the crank was striped out but, most will respond with a good cleaning/ lubrication/test. I have in the past bought the repop regulators I find the stock ones to work smoother& better! best of luck to you. cheers, Pat
