Old 03-12-2003, 07:58 PM   #1
GMC JUNKIE TOO
THE QUICKER FIXERUPER
GMC JUNKIE TOO's Avatar
6-lug question
Well its time for front disc brakes and a while back it was said that you could put brake rotors from an 88 up 6-lug 3/4 ton rotor on a 71-72 spindle no problems. I need to know for shure before I start, I have a 69 1/2 ton. I thought i could just buy drop spindles for stock balljoints and buy rotors and calipers for alot cheaper.
Allso the other day I had one of my crazy ideas and thought about puting a 99 up rear end in my truck but I dont know if its doable what do you guys (and gals) think.
Thanks Ben
GMC JUNKIE TOO is offline   Reply With Quote
Old 03-12-2003, 09:46 PM   #2
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
I can tell you what I am doing right now.
I have been converting my 70' over to frt disc.
these are the parts that i used all others are stock:
1) 6 lug rotors from GMC Paul (both rotors, inner and outer wheel brgs, calipers,hoses,pads,) $219 (or something close)
2) 73-87' 1/2 ton spindles heavy duty (for use with 1.25" thick rotors) not the 1" thick rotors (free, always someone dropping a chevy around here)
3) upper and lower ball joints for 73-87
4) outer tie rod end for 73-87
5) outer tie rod for 70 truck (for use as inner)
6) tie rod adapter sleeves( bought from case-bt, think they come from classic performance products) very nice product.
i also plan on buying brake lines from inline tube since mine are over 30 years old,
and i also need to buy a master cylinder and proportioning valve for the disc setup.
thats what i have been doing lately.
the other choices are buying a complete kit with spindles from a vendor,
swapping over a front crossmember from a 71-87 1/2 ton
or someone else said something about using the newer 6 lug rotors, but i don't remember the whole swap and what was involved
later
tommie
tommie is offline   Reply With Quote
Old 03-13-2003, 02:31 AM   #3
matt67350
matt67350's Avatar
Tommie, what brake line are you going to use if you are using the big brakes up front?
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 03-13-2003, 01:34 PM   #4
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
the rubber brake hoses came with the kit from GMC Paul, I am going to buy new brake lines(metal) from inline tube.
tommie
Old 03-24-2003, 04:46 AM   #5
outlaw
one thing I have learned is that nothing is impossible, someone will come up with a way to make it work
outlaw is offline   Reply With Quote
