Old 01-23-2011, 05:50 PM   #1
CrewCab59
CrewCab59's Avatar
WTB fleetside bed patch
Does and body have a bed patch for these 2 sections ( see pics )
outter 8x8 or 10x10
inner 5x5
zip to ship 37721
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 01-23-2011, 05:52 PM   #2
CrewCab59
CrewCab59's Avatar
Re: WTB fleetside bed patch
Here is the outter section.
1971 Chevy C/10
Old 01-23-2011, 06:57 PM   #3
72ArizonaBurb
I will take a look and see if my parts truck is good in that area. How do you want it cut out? 2 seperate pieces or cut completely across the top and down both sides?
72ArizonaBurb is offline   Reply With Quote
Old 01-23-2011, 07:07 PM   #4
Mt Man Chad
Mt Man Chad's Avatar
I had the same problem on a older rig, may not need complete patch
The outer you can use any door panel metal or any metal for that matter that is flat pc cut a circle to fit and bend by hand to match bedside curve. Inner pc a little harder to match but can be hammered out of stock sheet metal if needed.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 01-23-2011, 07:27 PM   #5
CrewCab59
CrewCab59's Avatar
What ever works best for you , seperate would be cheaper but more time to cut. Just let me know before you cut.
1971 Chevy C/10
Old 01-23-2011, 07:30 PM   #6
CrewCab59
CrewCab59's Avatar
The reason I wanted the patch is because the outter section is bent in into to different ways when they drilled the hole or when the fuel take was removed.
1971 Chevy C/10
Old 01-23-2011, 09:39 PM   #7
72ArizonaBurb
Mine is solid on both sides. I can cut it however you want. The inner one will be a little tougher to get out. Tell me what you think it is worth and you pay the shipping and I will get it out for you.
I would agree with the other post before mine that taking a piece of flat stock and working it to fit might be easier and cheaper in the long run.
Just let me know how you which way you decide to go and I will be glad to help you out. Just PM the details.
Thanks,
Keith
Old 01-23-2011, 09:56 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I have a junk bed you could come take the pieces off of in your own time,make me an offer or come get them for free.
(Im abit of a drive (probably 2 hrs or so)
John
1999 Toyota Tacoma 4x4
