01-23-2011, 05:55 PM | #1 |
W/C tremec 5 quetion
In my 67 i have a t18 right now and was given a t5 out of a 89 camaro. the problem is that it doesn't have a bell-housing. the question i have is if the t5 can bolt to the t18 bell-housing and work or do i need to buy a bell-housing and convert to hydraulic clutch? i know everyone hates these trannies but it was free and who complains about free right?
72 GMC Jimmy 8" lift 38" super swampers 77 GMC C15 High Seirra Short Step lowered 6/8 http://67-72chevytrucks.com/vboard/s...53#post8999053 1972 Plymouth Roadrunner 2005 Cadillac Escalade 2014 Ram Ecodiesel |
01-23-2011, 06:08 PM | #2 |
Re: W/C tremec 5 quetion
T5 is alright in the correct application. Especially the WC trans. The Camaro trans uses a rotated bellhousing, so if you mount the trans straight up, the shifter is rotated as well as the trans mount. It can be done and then you can modify a shifter handle and mount. Or you can change the tailshaft housing. Here is a site where you can get more info on T5's. You can read hours on this subject. T5's came in a lot of different vehicles, so lots of different combos. Mustangs, Jeeps, S-10, Camaro/Firebird, Datsun 280ZX Turbo to name a few. I think McCleod makes a scattershield that uses both trans patterns and lets you use mechanical linkage?
http://5speeds.com/
01-23-2011, 06:14 PM | #3 |
TY Mike I will have to get reading and this is for a mild daily driver mostly for my wife i have the jimmy once it gets done.
01-23-2011, 11:08 PM | #4 |
Too Dumb To Know Better
My brother has one in a 66. Have to shorten the input shaft, drill out some holes and probably chabge the cluth depending on how many splines you have.
Also, is it a mechanical or electric speedo? |
01-27-2011, 11:57 PM | #5 |
Low N Slow do did by chance do a build thread where he explained all of that? I would greatly appreciate it
