Old 01-23-2011, 06:09 PM   #1
nlped
nlped's Avatar
Another TV cable thread...help!
Okay, I did a search first, but didn't find an informative thread that answers my question/questions.
Quick background... 1976 2wd Blazer with a 350 small block that I have recently installed a 4L60 (not an "e") trans with the Bowtie Overdrive kit to control the overdrive with a cruise control style brake switch. I have run into a small issue with getting the correct TV cable bracket. I have a Quadrajet carb, but it says on the body of it that it was "built by Carter for GMC" and it seems to have the proper connection points for the TV cable (I've attached a picture so someone who knows this stuff can verify, hopefully). But, the ole '76 doesn't have a bracket in place for the TV cable as it had a TH400 prior to this install. Can one of you trans. fella's point me in the right direction for the correct bracket?
Recap... Carb. appears to have the correct mounting point for the TV cable, but the truck doesn't have a bracket to facilitate the 4L60 TV cable.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 01-23-2011, 06:10 PM   #2
nlped
nlped's Avatar
Re: Another TV cable thread...help!
The part # on the carb appears to be 1705?
Carter
Old 01-24-2011, 10:29 AM   #3
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=330265
Seems like the simplest way to do it is build your own if you're handy with sheet metal. Or 20 bucks for a house brand bracket at a parts store.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 01-24-2011, 11:36 PM   #4
bluex
bluex's Avatar
I got mine from BTO with the cable and linkage kit, but it was for a edelbrock 1406. Do they offer one for the quadrajet?
bluex is offline   Reply With Quote
Old 01-25-2011, 12:05 AM   #5
lindstromjd
Somewhere, yes, they do offer a different bracket for the Edelbrock. I just don't remember where I've seen them for sale.
-357 / 700r4
-350 / TH350
Old 01-25-2011, 06:47 AM   #6
S10Fan
Old Heap Driver
I've done business with these folks and was very satisfied. Give them a call.
http://www.transmissioncenter.net/
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-27-2011, 02:23 AM   #7
bluex
bluex's Avatar
http://www.bowtieoverdrives.com/cata...AT&CATID=WA3A4
Here is there page with brackets and other stuff. They dont list a kit for a 1705, they do for a 1905 however. Could that be the number on the carb? They are 129 with the standard cable and 159 with a braided one.
I purchased the braided line kit for my edelbrock 1406, got it setup and called them to verify the pressures. Everything was spot on and I have not had to touch it in 8 yrs. I would highly recommend getting one of those, just in case you need another bracket or something. It will be cheaper than having the trans rebuilt if its not adjusted right.....
Old 01-27-2011, 06:35 AM   #8
S10Fan
Old Heap Driver
From the picture I'd say your carb is a Quadrajet built by Carter, It's not a Carter AFB (Edelbrock) carb. Give us a shot of the complete carb.
Bryan
Old 01-30-2011, 10:45 AM   #9
nlped
nlped's Avatar
^^^I did say that it was a Quadrajet that is built by Carter.
Carter
Old 01-30-2011, 11:33 AM   #10
S10Fan
Old Heap Driver
Yes you did! I was concerned someone would post up a part number for an Edelbrock (AFB) style carb that wouldn't help you at all.
Bryan
Old 01-30-2011, 12:55 PM   #11
willett
Another Day, Another Dollar
willett's Avatar
excuse my ignorance, but what does a tv cable do
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 01-30-2011, 01:03 PM   #12
S10Fan
Old Heap Driver
700R overdrive transmissions use a "TV" cable that adjusts transmission pressure in relation to throttle position. Older transmissions used a "Kick-Down" cable, the 700R uses a different setup.
Adjustment/position of the cable is critical for 700R's.
Bryan
Old 01-31-2011, 05:13 PM   #13
nlped
nlped's Avatar
Gotcha! Thanks, dude!
Carter
Old 02-01-2011, 02:49 AM   #14
bluex
bluex's Avatar
I mentioned the edelbrock b/c thats what I have experience with. The links I posted are for quadrajets though, sorry for causing any confusion. I know how well the BTO kits work from using the one on my carb, they are expensive yes, but work extremelly well......
Did you get it fixed?
Old 02-04-2011, 11:41 AM   #15
nlped
nlped's Avatar
I haven't had any time to even look at the ole boy, but I'm going to probably just modify the stock throttle bracket and the throttle bracket from the donor truck and have me a hybrid bracket. Dang all that high dollar business... I'm poor
Carter
Old 03-02-2011, 12:59 PM   #16
nlped
nlped's Avatar
Well, I finally got around to fooling with the Bull last week and my modified bracket just wasn't fitting the bill. So, I did a little more research and found a very economical solution. TCI part # 376700 is a TV Cable Bracket for a 700R4/200R4 with a Quadrajet carburator. $21.36, 4 days of waiting around for the Fed Ex man, and 20 minutes of install time later...Poof, the ole boy works like a charm. Hell, I wished I had found that bracket 4 months ago, but I wasn't to motivated. But it's all good now
Carter
