Old 01-23-2011, 10:15 PM   #1
Pillow
Pillow's Avatar
LS Gen III attached to a 3 speed?
I know another LS motor swap question
Does anyone know if the LS engine will bolt up to a 3 On The Tree tranny?
The other questions on a motor swap are covered fairly well, except this.
... Yah, I like the old 3 speed.
The current 350 is sick and dying. A proper rebuild will run more than a motor swap from what I can tell.
Thanks!!!
PS: I lurk here a lot, but look for mild restoration to start in the spring. The I will be posting more often.
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King!
'83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress
'92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress
'79 Porsche 911 SC
'48 Spartan Mansion 30' travel trailer
'10 Porsche Cayenne S - Daily
Pillow is offline   Reply With Quote
Old 01-24-2011, 10:42 AM   #2
ls1nova71
ls1nova71's Avatar
Re: LS Gen III attached to a 3 speed?
It will physically bolt up with the exception of one bellhousing bolt. You'll have to change the clutch, and figure out a way to mount the clutch z-bar, as there isn't a provision for the pivot stud. I have not personally done it, but have seen Muncie 4 speeds behind LS engines. You might try a search for "Muncie 4 speed" on www.ls1tech.com, you,ll find something there that would help I'm sure.
Posted via telepathy
ls1nova71 is offline   Reply With Quote
