01-23-2011, 10:49 PM | #1 |
Radiator mounting pictures
I am in the process of restoring my 63 c10 and the previous owner installed what looks like a 60-62 radiator and hood. The frame has been notched and spacers to bolt it to the core support are made from uneven lenth conduit. I would like to repair the frame and save the radiator as it looks new. I am interested in pictures of 60-62 radiator mounts please.
01-25-2011, 06:27 PM | #2 |
Re: Radiator mounting pictures
Here's a 64 with V8 radiator, which is taller than the radiator for a 6-cylinder. Hope this helps.
I don't have photos of the lower mounts, but basically a V8 radiator sits on top of the frame rails in two U-shaped saddles. Last edited by MikeN; 01-25-2011 at 06:28 PM. |
01-25-2011, 06:38 PM | #3 |
As a follow-up, the 6-cyl radiator is narrower, slides down BETWEEN the frame rails, and rests on a light piece of angled steel, which is probably what your previous owner attempted to re-create with the conduit.
I appreciate your desire to save the radiator, but getting a new V8 radiator would eliminate any need to fabricate. As I said, the wider V8 radiator rests on TOP of the frame rails. You can get the lower saddles from someone like LMC, find a top mount like the one in my photos online or at a swap meet, and you're done. My radiator is a new stock replacement 64 C10 V8 radiator by Modine. I bought it several years ago at a local radiator shop for $240. It's also quite a bit more radiator, helpful when cooling a V8. Last edited by MikeN; 01-25-2011 at 06:39 PM. |
