Anyone bolt in notch?
Has anyone done a bolt in c-notch on a 72 2wd blazer? If so, which brand did you use? any issues with the rear frame horns?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
![]() Join Date: Aug 2005
Re: Anyone bolt in notch?
Never done it, but I believe any of the 67-72 truck bolt in ones would work.
I used the cpp version. It bolted in with no issues.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
considering the same thing...would love to see pics of total drop with bolt in and installation pics if possible.
needs more $$$
I mine a few weeks ago, nothing too bad except for stubborn rivets. I used CPP's, and as long as you have a true 2wd frame with coils, it should bolt in like any other truck. I liked CPP's since it' referenced off exisiting holes to make the cuts easier to determine where they should be.
I didn't take any pics of it, but I used this link from Rokcrln as a guide: http://67-72chevytrucks.com/vboard/s...d.php?t=195566 OG2wdblaze: I had a 4/6 drop on mine without a notch and I only bottomed out a few times. The pic is with 22's and about a 31" tire. I'm still in the middle of bagging it, and with a 2" block, bags and c-notch, the rear tucks tires with no air.
1970 2wd Blazer |
This is coming from a 4x4 guy - that is one nice looking Blazer
wow, I need to do some more research...Im not sure that is much lower than what Im sitting at now. Thoughts?
#8 | ||
needs more $$$
1970 2wd Blazer |
