01-24-2011, 12:22 AM | #1 |
Recommend a rear setup...
I have my frame apart and was wondering what is a recommended setup for lowering the rear as low as possible without altering the floor. Right now i have 2 bags. What other products would be useful?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
01-24-2011, 01:17 AM | #2 |
Re: Recommend a rear setup...
We offer a couple different variations of a "Stage 2" kit that will accomplish what you are looking for. Here are a couple build threads with our Stage 2 kit:
http://67-72chevytrucks.com/vboard/s...d.php?t=414742 http://67-72chevytrucks.com/vboard/s...d.php?t=438156
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 01-24-2011 at 01:17 AM. Reason: grammar |
01-24-2011, 11:22 PM | #3 |
67-72 parts collector,…
I recommend the above mentioned Porterbuilt products!^^^
If you can't fit them in your budget,... at least install a set of rear shock relocators, a good set of quality drop shocks, and an adjustable track bar. (panhard bar)
01-25-2011, 11:08 PM | #4 |
Does your truck have a notch? Unfortunately, i can't afford the PB stuff... my plan is a notch, shock relocators, shocks of some size, and a trac bar. I am not sure of do i need the super trac bar or regular adjustable one.
01-25-2011, 11:22 PM | #5 |
I like the Super Track Bar from ECE, with a max static drop (5"-7.5" rear drop) or bagged drop.
My red '69 has a 6" rear spring and a 1.5" block with a bolt-in c-notch, shock relocators and drop shocks. My '71 blazer is bagged with the same notch, 2" blocks, shock relocators and drop shocks.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-25-2011 at 11:22 PM. |
01-25-2011, 11:53 PM | #6 |
We also offer a "basic" version of the stage 2. It allows you to keep your factory trailing arms and factory trailing arm x-member. It includes our 2-piece notch, shock relocator system, shocks, trac-bar, bags, and all hardware/bracketry. You can e-mail me or pm if you have any questions.... if my product isn't within the budget, I will still be happy to help you find something that works for you.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
01-26-2011, 02:48 AM | #7 |
Nate - do you recommend using a block with this kit? 1"-2"? thanks
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com |
01-26-2011, 04:55 AM | #8 | |
chevy runs deep
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
01-26-2011, 11:42 AM | #9 | |
With the basic kit (uses factory trailing arms), your axle will bottom out in the notch before the bags and shocks reach their maximum compression.
01-26-2011, 11:45 AM | #10 | |
The basic kit runs $699 It includes: Slam SS7 bags (2) KYB shocks with mounting hardware Shock relocation system Porterbuilt trac-bar (fully adjustable with rod ends and hardware) Porterbuilt 2-piece notch with all mounting hardware. Here's a link: http://porterbuiltstreetrods.com/sit...y-version-699/ Just give me a call to set up a time and you are welcome to come visit.
01-26-2011, 12:23 PM | #11 | |
How did you route the exhaust with this setup? Also, Nate was nice enough to show me around his shop a few months ago. He really is a cool guy. |
01-28-2011, 01:47 PM | #12 |
ttt
