Sealing Gaping Wound under the cab from manual tran change; PIC
hey guys, this is what i have goin on, pic shows pretty well whats going on. i think im going to have to fill the gap with something after i get that grease out of there. the problem is, there is a gap about a half inch wide all the way around that lip. what should i use to fill here guys? thanks! (metal is going to be prepped and painted before anything is applied to seal this problem area.
Re: Sealing Gaping Wound under the cab from manual tran change; PIC
Will a high hump cover cover the whole area? It is hard to tell from the picture but it looks like a hump cover would come close to covering the area that someone chopped out.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
hump cover? do you have a link to a pic? i have no idea what that is
