Old 01-24-2011, 05:10 AM   #1
Jay290
Dual Fuel Tank Conversion
Hello I've got an 83 SWB it came with a single tank I'm curious if it would be worth the trouble to try and install a second tank in this thing. Or would it just be easier to just install a 22 gal fuel cell in the bed?
Jay290 is offline   Reply With Quote
Old 01-24-2011, 05:43 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Dual Fuel Tank Conversion
Welcome to the site. Why not add 45 gallons!! Yea!! You can add a suburban or Blazer tank where the spare tire mounts!
Blazer tank install: http://www.captkaoscustoms.com/blazertank.html
Fuel cell: http://www.73-87.com/7387garage/chas...ellinstall.htm
I have dual tanks on my 83. Cruise range is almost ~275 miles per tank! 500+ miles with both full tanks if I keep my foot out of it.
Get a catalogue from www.lmctruck.com. You can find all the stock parts you need. You will need to add a second fuel door or swap beds. I replace the origina bed on my truck. I found a single tank SWB bed. I had the passengerside fuel door added to the replacement bed.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-24-2011, 05:55 AM   #3
Jay290
Well when I did the body work on the truck I had to replace the pasenger side bed side I went ahead and got the one that had the fuel door in it. What all would I need to add. I know the selector valve, tank, fuel line and the switch inside the cab. Is there any pictures of the factory setup or some kind of diagram?
Old 01-24-2011, 10:35 PM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
As far as the wiring goes if it were me, I'd locate one in a wrecking yard that had what I need for the wiring harness, carefully disconnect and remove it all without cutting anything anywheres then reinstall it all into my truck.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-25-2011, 12:01 AM   #5
rayfinseats
I own a 83 dual tank 4x4. I wont be looking at til spring though.
rayfinseats is offline   Reply With Quote
Old 01-25-2011, 12:38 AM   #6
orbot
orbot's Avatar
I would do the blazer/burban tank..stockish look and cheapper id say, i already have the twin tank set up and they are nice but they are small as well
orbot is offline   Reply With Quote
Old 01-25-2011, 04:36 AM   #7
Jay290
Yah I'm wanting a few more miles out of it in between fuel stops, the one 16 gallon tank does not go very far in these things...kind of guess it would if I would keep my foot out of it. I will go and look through some of the salvage yards and see what I can find. When the 700r4 goes in next week it should help out a little.
