![]() Join Date: Jan 2011
Would a 99 tranny fit in my 78
I have a 78 c10 and the 700r4 crappped on me last night. would the trans out of a 99 swap over or would i have to take the nasty fuel injection motor with it?
Re: Would a 99 tranny fit in my 78
It will bolt up to the engine but thats about it. You would need some kind of controller for it to shift and probably modify everything else from the crossmember to the driveshaft
you just have to move the cross member back and depending weather you have a short shaft or a long shaft in your 78 depends weather you will have to shorten your drive shaft any. the 99 trans will bolt in and work just fine but you will need a controler and to convert the speedometer to mecanical drive.
![]() ![]() Chris67 c10 swb build in progress 70 c10 lwb driver pending parts for drastic overhaul 70 c20 lwb parts truck for above mentioned drastic overhaul 71 k20 lwb building for off road use and towing |
Addicted to Rust
![]() Join Date: Dec 2009
The ls trans will not fit the old style block without some spacers or adapters. the crank flange dimension to the bock face is different. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
Does the 99 have a 4.3L V-6?
CHEVY ONLY
Rusty Rockerfeller
![]() Join Date: May 2003
#7 | |
Addicted to Rust
I would just pull your 700r4 and have it rebuilt would be the easiest way.
![]() Join Date: Sep 2010
http://www.bowtieoverdrives.com/cata...SUBCAT&CATID=B pricing isnt too bad on these
1985 c10 355 th350 (working on 4 speed conversion to super t10) 1979 camaro 358 super t10 2003 f250 superchip slp exhaust |
#11 | |
Last edited by 198ChevyGuy; 01-26-2011 at 09:21 AM. Reason: fast hands slow brain |
^ double check your date, that should be a '92, GM went to the 4L60E in '93. You should have one of the best 700's, though.
Good luck, hope it goes well. |
| Bookmarks |
