Old 01-24-2011, 02:14 PM   #1
1968CHEVYC10
1968CHEVYC10's Avatar
Antifreeze in oil?
Over the last month when I check my oil, I've been noticing some light gray slimy stuff on the dipstick, also about a month ago I changed out my thermostat, and since then there's been a small leak around there, you can see a small puddle of antifreeze on the intake manifold every now and then. So I just got to thinking, could antifreeze be getting into the oil and that account for the gray slime on the dipstick?
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 01-24-2011, 02:25 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Antifreeze in oil?
Yes and I wouldnt drive it much if at all, the antifreeze will ruin your oil and hinder what it is there for. I would fix the thermo housing and then change oil, run for a little bit and change the oil again.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-24-2011, 02:36 PM   #3
71swb4x4
71swb4x4's Avatar
More than likely the gray slime is just condensation. Here is South Dakota we get that for a solid for four or five months when it's really cold. In Texas it probably rarely gets cold enough to see it, so that's why it's alarming to you.
Now if all of the oil on the dipstick is the gray stuff, you have a problem. If you are worried just drain the oil. If the oil looks normal it's probably just condensation.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-24-2011, 02:47 PM   #4
longhorn396
S.D.M.F.
longhorn396's Avatar
Headgasket? maybe??
1969 Chevy Longhorn 396/400 3/4 ton.
1991 Chevy Camaro RS 305/700r4
1978 Honda XL175 and XL350(the evil twin)
2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous
1971 BSA Thunderbolt 650cc
longhorn396 is offline   Reply With Quote
Old 01-24-2011, 02:50 PM   #5
matthew20061
69' Chevy Stepside
matthew20061's Avatar
When you get antifreeze in the oil it will most likely start smoking white and smell like burning antifreeze.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 01-24-2011, 02:51 PM   #6
Shane
Shane's Avatar
a leaking intake manifold gasket will also allow water to get in the oil ...
Shane is offline   Reply With Quote
Old 01-24-2011, 03:09 PM   #7
treveiger
treveiger's Avatar
Lol i noticed that a few weeks ago, wondered what it was but didnt think much of it. Thanks!
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-24-2011, 03:16 PM   #8
big_al_71
big_al_71's Avatar
In miami I would think either a blown head gasket or a leaking intake manifold gasket...As already suggested drain the oil and see what it looks like..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-24-2011, 03:26 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
That will happen when water/antifreeze gets into the cylinder... not the crankcase.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-24-2011, 04:09 PM   #10
1968CHEVYC10
Wow thanks for the help y'all, not sure if it makes a difference but thought I'd mention, the oil on the dipstick was always clean, the slime was usually further up towards the top of the dipstick. I do plan on fixing the leak soon no matter what the slime is.
Old 01-24-2011, 04:42 PM   #11
matthew20061
69' Chevy Stepside
Gary
Your right I don't know what I was thinking, I bought a 96 gmc once with blown head gaskets and it was smoking like crazy because of the coolant getting into the cylinders and leaking intake gasket. I checked the oil and the engine was literally half full of coolant probably around a gallon of antifreeze mixed with oil. Rebuilt the heads, new head gaskets, and intake gaskets and it ran perfect. It was my first truck and I drove it for two years with no issues.
-Matthew
Old 01-24-2011, 05:45 PM   #12
57larry
I'm thinking headgasket
57larry is offline   Reply With Quote
Old 01-24-2011, 10:25 PM   #13
1968CHEVYC10
I take back what I said about the oil being clean, just checked it... it wasn't clean. Oh well anyway got a new gasket and thermostat (it wasn't running hot enough with the 180deg I put in last time) so tomorrow I'll get the leak fixed and changed the oil. If there are some problems with the other gaskets ie. intake and head, then hopefully it'll be ok till I can get my new motor swapped in. Thanks for the help y'all!
Old 01-24-2011, 11:28 PM   #14
sjarrett71
sjarrett71's Avatar
I've never known a thermostat gasket to let antifreeze into the crankcase. I think you have other issues.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 01-25-2011, 11:49 AM   #15
The t-stat gasket leak is unrelated. It just started leaking because you didn't get it sealed well. That's external. It will be one of the problems already mentions and you should not drive it or you'll need main bearings,etc. Check for bubbling water in your radiator.
