Old 01-24-2011, 07:44 PM   #1
jeremy zander
jeremy zander's Avatar
Lockers???
Dana 44 front ho52 rear...Where can I get some lockers??Any experiences??
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 01-24-2011, 08:45 PM   #2
SeventyOne
Re: Lockers???
Google search "Dana 44 lockers" and you will get more than enough info. Find what you want (mechanical, air, electronic, cable) and then find the best price - just depends on what you're looking for.
Completeoffroad.com is one place...
As for a Ho52...I don't know but I found this:
http://67-72chevytrucks.com/vboard/s...d.php?t=182961
I would just swap in a 14bolt for more readily available parts and better aftermarket.
Good luck.
SeventyOne is offline   Reply With Quote
Old 01-24-2011, 08:57 PM   #3
Mike C
Mike C's Avatar
Re: Lockers???
Factory no-spin for the HO5200 if you can find one. But I think you can swap the 14 bolt locker in if you use the 14 bolt axles. Obviously you need to find a 14 with the correct length (or close!) axles or buy some cut-to-length aftermarket ones.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-24-2011, 10:33 PM   #4
Husker
Husker's Avatar
Re: Lockers???
Ihave detroit true tracs front and rear in my CJ5 and they do real well, can not even tell they are there but all four tires spin in 4 wheel drive.
Will probaly install one in the rear of my 70 GMC 4x4.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 01-25-2011, 01:43 PM   #5
jeremy zander
Re: Lockers???
Ordered a detroit true trac locker last nite... d44 ..thanks for the suggestions....
Old 01-25-2011, 04:15 PM   #6
Re: Lockers???
You'll like that up front. That's what I run. Keep an eye on the parts board for an HO52 No-Spin. I've bought two from Teeitup. You can have the drop-out diff sent and just bolt it in. It's worth the extra shipping IMO.
