Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-24-2011, 08:27 PM   #1
C-10 simplex
8.5" vs. 8.6" 10 bolts:
How does the 8.6" 10 bolt compare to the 8.5" in terms of design and strength?
i think the 8.6 comes in newer 2000 and later 1/2 tons.
C-10 simplex is offline   Reply With Quote
Old 01-26-2011, 09:23 PM   #2
team39763
Re: 8.5" vs. 8.6" 10 bolts:
I see a lot of guys going fast on the 8.6 and I don't hear a lot about them breaking anything. I know they have 30 spline axles compared to our 70's to 80's model trucks with 28 splines. I'd imagine they'd be slightly stronger.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 04-04-2011, 03:04 AM   #3
C-10 simplex
So how much power (hp and tq) can each of the rear diff assemblies take?
8.5
1a) 3000lbs with 4.56 gear
b) 3000lbs with 3.73 gear
c) 3000lbs with 2.56 gear
2a) 2500 lbs with 4.56
b) 2500 lbs. with 3.73
c) 2500 lbs. with 2.56
3a) 1900 lbs. with 4.56
b) 1900 lbs. with 3.73
c) 1900 lbs with 2.56
4) everything identical to all scenarios above EXCEPT with an 8.6 rear.
Old 04-04-2011, 04:30 PM   #4
1970C10truck
1970C10truck's Avatar
I dont think its so much how much power can they take its more or less how hard they get hit when they hook. When I was a kid I had a chevy luv with a 327 in it on the stock rear end. It lived for a long time on street tires. The first time I got the slicks hot and launched it hard it was broken.
1970 C10 swb 350 4spd under construction
1970C10truck is offline   Reply With Quote
Old 04-05-2011, 12:11 AM   #5
Captainfab
60-66 Nut
It is all relative to what tire you are bolting onto a given differential.
