Best bang for the buck?
i am new to the 99 and up trucks and i was woundering whats the best power upgrade for the money. i have a 00 1500 2wd 5.3 already got a aftermarket intake and did a muffler delete thanks
![]() Join Date: Aug 2004
Re: Best bang for the buck?
All depends on who you talk to and how much you would like to spend. One thing is for sure though, these trucks have computers that will need programing after most modifications. A good programmer costs $90 and hour. I have found alot of help about my newer trucks at performancetrucks.net over there is mostly guys with the newer trucks. I have 5 trucks from 67-70 and two 2000's and one 2002 I jump back and forth between sites. John
Truck Enthusiast
i'd look into a tune or some electric fans next. you will notice a difference in both right away
'85 swb |
thanks for your reples i did a efan. cheep autozone set up but it works i guess. i need to find a local tuner.
yes, i do
also look into underdrive pulleys. but most of the info that i have gotten so far about my 01 tahoe is from ls1truck.com. lots of good info there. i think there's a couple of members here that are members over there too
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
The tune first. Since you have e-fans, Id go with headers and duals next. ANd of course your cold air intake is a good supporting mod, but go to siliconeintakes.com and make your own like I did. In my sig I listed the Trucool 40K as a mod, its a trans cooler and a big one at that. It dropped my trans tempts hugely. Heat is the #1 killer of transmissions so I'd look into one.
should i go with a programmer? are they really worth it? and if i go with headers what do i do about the o2s? i live in a emissions area
I'd go with a custom Tune over a programmer any day.
As far as the 02's I guess youd have to do shorty headers Posted via Mobile Device |
There is a good programmer just minutes north of you in Richmond, pm me and I'll put you in contact with him if you like. I trust him and so will you after you meet him. John
Has more rust than truck...
Get a custom tune HANDS DOWN!!!!!! Also the corvette trans servo is cheap and very effective if you like a bit firmer shift.
69' Chevy Stepside
![]() Join Date: Mar 2008
From what I have experienced, a Tune and Long Tube headers are great cheap upgrades that yeild very good gain. As stated electric fans are also a good one. I've got Efans and I did a tune on my Silverado SS and it runs awesome!
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
#13 |
thank all that have replied your help is very helpful
#14 |
Mechanic, tuner, motors, trans, rearends, etc. The guy makes things run awsome Thanks
#15 |
motor exploder
Hands down the best mod I've done so far was sending my ECM to Justin Gadberry at Blackbear Performance. I have a K&N FIPK, true duals, and efans (05 came stock with them
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
