Old 01-25-2011, 03:55 AM   #1
65Pickup
65Pickup's Avatar
60-66 Small Block Headers for 500 to 600 hp
What's everyone making serious small block power running for headers? I'm not having any luck finding 1 3/4" primary tube headers. Are custom headers the only option.
65Pickup is offline   Reply With Quote
Old 01-25-2011, 05:59 AM   #2
Rannos
Rannos's Avatar
Re: 60-66 Small Block Headers for 500 to 600 hp
I have run a few different headers. 73-87 chevy truck headers work if you use tubular engine perches like the ones from CPP. Altho I personally am running the Schoenfeld camaro (part number 186-3) headers in my truck for lack of options with angle plug heads. Is a tight fit but they work. I am using the tubular engine perches and tranny crossmember from CPP with them. Hope this is helpful.
Rannos is offline   Reply With Quote
Old 01-25-2011, 12:04 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Check with Hedman and Doug's...I'm pretty sure they offer header part numbers for SBCs with 1.75" primaries.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-25-2011, 03:24 PM   #4
65Pickup
65Pickup's Avatar
Hedman's says a custom set will be the only option, Doug Thorley same, still trying to connect with Doug's headers. Thanks, even the parts store guys are coming up with nothing.
Old 01-25-2011, 03:26 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
have you looked for headers for 68-72?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-25-2011, 04:18 PM   #6
65Pickup
65Pickup's Avatar
Thanks Rannos, Schoenfeld looks like a winner.
Old 01-25-2011, 04:50 PM   #7
65Pickup
65Pickup's Avatar
That appears to be the solution, I needed to hear from someone who has done it. Slooter on here did just that, knowledge is power. thanks
Old 01-26-2011, 01:22 AM   #8
Captainfab
60-66 Nut
Hedmann lists the same 1 3/4" primary tube headers for the '67-'72's as for the '73-'87's.
Old 01-26-2011, 01:40 AM   #9
bama63
bama63's Avatar
for big horsepower small blocks use the Schoenfeld hi-velocity step headers #116V 1 3/4" - 1 7/8" tubes and 3 1/2" x 9" collectors link-http://www.schoenfeldheaders.com/drag.htm a really good performance header, drivers side is close but will clear pass side has plenty of room
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 01-26-2011, 01:42 AM   #10
65Pickup
65Pickup's Avatar
Thanks Captain, that appears to be the one I need. Another poster named Slooter is running them. I was trying to find someone who has them on their truck before I order them. Thanks for the post and leg work. Schoenfeld may have one also, they don't take email so I have to phone or fax them. That's the cool thing about this site, learn from others before you lay down your bread, I'm not doing anything unique. Also this truck is kinda rare around here, but almost common in the States (many more people and rust free projects), the knowledge goes deep. Later
Old 01-26-2011, 01:45 AM   #11
Captainfab
60-66 Nut
There was also another thread about large tube headers today in the 'Racing and High Performance' section. Schoenfeld was mentioned there also.
Edit: Never mind.....I now see that, that was you.
Old 01-26-2011, 02:51 AM   #12
65Pickup
65Pickup's Avatar
that's cool nice you got my back...its amazing how you can ask something on these posts and then see your answer two pages later. Appreciate the effort.
big horsepower, headers, small block
