Old 01-25-2011, 09:49 AM   #1
jasonroman
jasonroman's Avatar
how hard is it to change steering column?
when i bought truck the column had some shake to it. and the blinker part was cracked. the arm that controls the turn signals...= blinker part
since having the truck, if i pulled the arm to say, put on high beams, i would loose all lights..??
then last night went to get in truck and go to work. and no headlights.
i tried pulling the lever and nothing would happen. but i didnt hear the thing engaging like i would in the past. at the point where id loose headlights.
so im thinking i might want to start looking for a new column.
to get rid of the wiggle and have no broken blinker arm.
also wondering what i need to do to get the water to shoot on my glass??
wipers work. but no water action. tank is full, just no squirting/.
as always, thanks for any help
jasonroman is offline   Reply With Quote
Old 01-25-2011, 10:25 AM   #2
ghettoluxury
ghettoluxury's Avatar
Re: how hard is it to change steering column?
The column is very easy to change out. 2 bolts under the dash, about 5 on the inside fire wall, 2 plugs, if an auto a pin for the steering linkage, 2 bolts on the outside of the fire wall, and 3 bolts for the steering shaft. The pump in the washer tank is probably bad.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-25-2011, 11:44 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Note that there are some differences in year models. Most will physically fit, but early ones had wiper/washer on dash, and the plugs and pins are different too.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-25-2011, 12:59 PM   #4
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Good Morning,
WW system could simply be plugged, a hose or even the little screen at the bottom of the reservoir. Check this first and make sure that nozzles will pass air as well. If they are plugged try cleaning them out with a thin wire.
To do these things is free.
God Bless, Terry
77 350 Shorty Wide is offline   Reply With Quote
Old 01-25-2011, 02:48 PM   #5
jasonroman
jasonroman's Avatar
thanks for reply folks
ill check and see wat i can find with the windshield wiper issues.
truck might be coming off the road soon. guess that will be when i try and figure out the column swap.
trucks an 85 with tilt. i guess ill look for something in that yr range to avoid problems
Old 01-25-2011, 05:40 PM   #6
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
I did the same thing on my Custom Deluxe with no tilt.
Fairly easy gig...
1984 is when they relocated the wiper switch to the signal stat... along with the delay and cruise.... so 84 on up, and your good.
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
